Can the work in a isochoric process be non zero?
In summary, Joule showed that the change in internal energy of a system is inversely proportional to the temperature rise.
Soren4
128
I came up with a doubt regarding isochoric irreversible processes. Is it always true that, for any isochoric process, reversible or not, the work exchanged by the system is zero and the heat exchanged is ##Q=\Delta U##?
I'm asking this because, in a exercise on thermodynamics trasformations of a gas, there was to be considered an "isochoric irreversible transformation in which the tank containing the gas is thermically isolated and work is done on the gas with a fan of negligible thermal capacity, the gas goes from ##T_a## to ##T_b##".
Now if the tank is isolated ##Q## should be ##0## but that cannot be, since the gas changes its temperature and the process is isochoric. Furthermore it is said that work is done on the system, but the process is isochoric, how can that be?
Nothing else is specified on the trasformation so in my view it can be a case where it does not matter at all how the process is done, as long as ##V_{final}=V_{initial}## the process is isochoric and the total work done on the gas will be zero (maybe some positive and some negative), but still I don't see how the gas can exchange heat in this case.
So do I have to care about it or, in any isochoric trasformation I can be sure that ##W=0## and ##Q=\Delta U##?
Likes Delta2
P-V work is not the only kind of work that can be done on the contents of your system. In the case of your fan example, the fan is doing work on the gas within the container by exerting force on it through a displacement (of the fan blade). The kinetic energy imparted to the gas by the fan is then converted to internal energy by viscous dissipation (a damping effect). So the net effect is that the work done by the fan increases the internal energy of the gas.
Likes Soren4 and Delta2
Thanks for the reply! So in this case, ##Q=0## and ##W_{fan}=\Delta U##? (Or equivalently ##-W_{gas}=\Delta U##, since ##W_{fan}=-W_{gas}##)
But that's look more like an adiabatic process.. Effectly the tank is isolated so the process is also adiabatic, beside isochoric..
In conclusion, if I got that right, it is wrong to say: isochoric ##\implies W=0##
Yes.
Yes. If the tank is insulated, then the process is adiabatic.
Yes. Isochoric means no P-V work.
In Joule's famous experiment, he ran a paddle wheel inside an insulated container of water, by attaching the paddle wheel to a rope and pulley arrangement, driven by a descending weight. The change in potential energy of the weight was equal to the work that the paddle wheel did on the water (and the change in internal energy of the water). He measured the rise in the water temperature as a result of the viscous dissipation of the mechanical energy. By doing this, he was able to establish the equivalence between the work done in N-m (Joules) and the change in internal energy of the water. And he was thereby able to determine the relationship between the change in internal energy and the temperature rise.
Related to Can the work in a isochoric process be non zero?
1. What is an isochoric process?
An isochoric process, also known as a constant-volume process, is a thermodynamic process where the volume of a system remains constant while energy is transferred into or out of the system.
2. Can work be done in an isochoric process?
Yes, work can be done in an isochoric process. However, since the volume of the system remains constant, the work done in this process is typically zero.
3. How is work calculated in an isochoric process?
The work done in an isochoric process is calculated as zero, since the volume remains constant. This means that there is no change in the system's internal energy, and therefore no work is done.
4. What factors can affect the work done in an isochoric process?
The work done in an isochoric process is affected by the initial and final temperatures of the system, as well as any changes in the number of moles of gas present. The type of gas and any external forces applied can also influence the work done.
5. Can the work done in an isochoric process ever be non-zero?
In theory, the work done in an isochoric process can be non-zero if there is a change in the temperature of the system. This would require a change in the internal energy of the system, which can be converted into work. However, in most practical cases, the work done in an isochoric process is considered to be zero.
  • Other Physics Topics
