MHB Can These Expressions Be Factored Correctly?
  • Thread starter Thread starter mathdad
The discussion focuses on factoring three algebraic expressions. The first expression, 4u^2 + 25v^2, is confirmed to be irreducible over the integers. The second expression, (81/4) - y^2, is correctly factored into (9/2 - y)(9/2 + y). For the third expression, 8a^3 + 27b^3 + 2a + 3b, the application of the sum of cubes is appropriate, but caution is advised regarding variable names to avoid confusion. The participant expresses a lack of access to a computer and plans to share images of their work for clarity.
mathdad
Factor the following three questions.
1. 4u^2 + 25v^2
I say this one cannot be factored because the expression is irreducible over the integers.
Right?
2. (81/4) - y^2
Let (81/4) = (9/2)(9/2).
So, (81/4) - y^2 factors out to be (9/2 - y)(9/2 + y).
Right?
3. 8a^3 + 27b^3 + 2a + 3b
I must apply the sum of cubes to the expression 8a^3 + 27b^3 as a first step, right?
If so, then a = 2^3 and b = 3^3 in the sum of cubes, right?
I did not ask for the problems to be solved. I simply want to know if my work is correct or not. If it is wrong, make the corrections and allow me to do the math.
Mathematics news on Phys.org
1. Correct.
2. Correct.
3. Yes, apply the sum of cubes formula to $8a^3+27b^3$. Be careful with your variable names. $a$ does not necessarily equal $2^3$. In another post you stated $a=(a+b)$. This is only true if $b=0$. Try choosing different letters for different variables. For example, you may be given to factor
$$125a^3-64b^3$$
Then write
$$p=5a$$ and $$q=4b$$
It makes no real difference what other letters you choose; these letters reflect given values no matter what they are.
It is entirely incorrect to state $a=5a$ and $b=4b$ in the context you are working in. At any rate, those two equations are only true if $a$ and $b$ are equal to $0$
Have you thought of learning $\LaTeX$? :)
greg1313 said:
1. Correct.
2. Correct.
$$125a^3-64b^3$$
Then write
I do not have a computer. No time to learn LaTex. I will try to post pictures of my work for easy reading. Thank you for your help.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
