Can this be solved without a knowledge of turbines?
In summary: However, the actual calculations will depend on the specific design and conditions of the hydroturbine setup. It would be best to consult a hydraulic engineer for a more accurate calculation.
BigWill
1) 10 Hydroturbines are in a line, fitted inside a 1m diameter vertical tube its height 1.2km.
The top of the tube is 100m deep underwater in a high mountain saltwater lake.
This 1200m long tube acts like an orthogonal drainpipe down the mountain.
Hdyroturbine-A, hydroturbine-B,...Hydroturbine-J.
These ten hydroturbines are spaced 100m apart and the first turbine-A is located 100m down the tube giving the head of water (200m) on the first turbine. Each turbine is 100m below the one above with a height from the last hydroturbine-J of 100m to the bottom of the tube which is 50m above sea level, falling freely.
2) The flow rate through each turbine is governed by the turbine aperture and allows 1m3/sec flowrate ( tube is 1m in diameter).
3) Is it right to say that the head of water that reaches each turbine-A to J will be the product of the head of water between each turbine (100m) plus the weight of water above it multiplied by gravity minus resistance of turbine blades at each hydroturbine and the resistance of the tube walls? The outlet at the bottom of the tube falls into an open reservoir depressurising the water.
4) Decide on which is the best hydroturbine for this application ( Impulse??),
http://energy.gov/eere/water/types-hydropower-turbines
and calculate the power produced at each turbine (A to J) then the sum of the power produced.
Resistance losses are also to be calculated in each turbine (Rt) and the wall resistance (Rw) of the vertical tube, should be less important.
I hope to have some responses soon to discuss how to solve.
Many Thanks
Will
If you assume each turbine captures all available energy (ideal case) then the head for each turbine is 100m (200m for first one).
Total power available = m[dot]gh = 1000kg/s * 9.81m/s^2 * 1200m = 11.8 MW
This is the upper limit. Actual output will depend on how realistic you want (or can) be.
Thanks for your input Billy,
As turbine blade resistance losses could be significant but the resultant of the water head height should add to the total force experienced at each succeeding turbine. What is the way to calculate effective head at each subsequent turbine further down the tube after the losses from energy extraction and electricity production?
Ignore anything that happens in the turbine, overall turbine efficiency takes all of that into account.
The Bernoulli equation
I would say that it is possible to solve this problem without prior knowledge of turbines, but it would require a thorough understanding of fluid dynamics, gravity, and resistance. The equations and principles involved in this scenario can be complex and may require specialized knowledge to accurately solve.
In order to accurately calculate the power produced at each turbine and determine the best type of turbine for this application, it would be necessary to understand the specific characteristics and capabilities of different types of turbines, as well as the effects of resistance on their performance. It would also be important to consider the flow rate and head of water at each turbine, as well as the weight of water and gravity.
Additionally, the design and construction of the vertical tube would play a significant role in the overall performance and efficiency of the hydroturbines. The resistance of the tube walls and the impact of depressurizing the water at the bottom of the tube would also need to be taken into account.
In summary, while it may be possible to solve this problem without prior knowledge of turbines, it would require a deep understanding of fluid dynamics and other scientific principles. It would also be important to have access to accurate data and information about the specific components and conditions of the system in order to accurately calculate and determine the best solution.
Related to Can this be solved without a knowledge of turbines?
1. Can turbines be replaced with other technology?
Yes, turbines can be replaced with other technologies such as solar panels, wind turbines, or hydroelectric generators. However, the efficiency and effectiveness of these alternatives may vary depending on the specific situation.
2. How important is knowledge of turbines in solving energy-related problems?
Knowledge of turbines is crucial in solving energy-related problems. Turbines are a key component in many power generation systems and understanding how they work is essential in optimizing their performance and troubleshooting any issues that may arise.
3. Can someone without a background in engineering understand turbines?
Yes, with some research and learning, someone without an engineering background can understand the basic principles of turbines. However, a deeper understanding and ability to design and troubleshoot turbines may require a more specialized education.
4. Are there any alternative energy solutions that do not involve turbines?
Yes, there are alternative energy solutions that do not involve turbines, such as geothermal energy, biomass, and nuclear power. However, many of these technologies still use turbines in some capacity as part of their power generation process.
5. Can turbines be used for purposes other than energy production?
Yes, turbines can be used for various purposes other than energy production, such as in jet engines, water pumps, and even in certain types of toys. However, their use in these applications may differ from their use in energy production and may require a different level of understanding.
  • Materials and Chemical Engineering
38K
