Can This Differential Equation Be Solved with Given Initial Conditions?
  • MHB
  • Thread starter Euge
In summary, a differential equation is a mathematical equation that relates a function's rate of change to the function itself. To solve a differential equation, one must identify its type and choose the appropriate method, such as separation of variables or integrating factors. These equations have various applications in science and engineering, such as modeling population growth and fluid dynamics. Not all differential equations have analytical solutions and may require numerical methods or approximation techniques. Differential equations are essential for understanding and predicting the behavior of systems in various fields.
Euge
MHB
POTW Director
2,073
244
Here's this week's problem. Happy holidays, everyone!
_________________
Problem. Find the solution of the differential equation
\(\displaystyle y\ddot{y} - \dot{y}^2 - y^4 = 0\)
subject to the conditions $y(1/2) = \pi$ and $\dot{y}(1/2) = 0$.
_________________
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered this week's problem. Here is my solution.
The solution is $y(t) = \pi \csc(\pi t)$. To see this, add $y^4$ to both sides of the ODE, then divide through by $y^2$ to get
\(\displaystyle \frac{y\ddot{y} - \dot{y}^2}{y^2} = y^2\)
\(\displaystyle \left(\frac{\dot{y}}{y}\right)^{\dot{}} = y^2\)
\(\displaystyle (\log y)^{\ddot{}} = y^2\)
Employ the $u$-substitution $u = \log y$ to obtain
\(\displaystyle \ddot{u} = e^{2u}\)
\(\displaystyle \ddot{u}\, \dot{u} = e^{2u}\dot{u}\)
\(\displaystyle \left(\frac{\dot{u}^2}{2}\right)^{\dot{}} = \left(\frac{e^{2u}}{2}\right)^{\dot{}}\)
\(\displaystyle \dot{u}^2 = e^{2u} + C\)
Since $u(1/2) = \log y(1/2) = \log \pi$ and $\dot{u}(1/2) = \frac{\dot{y}(1/2)}{y(1/2)} = 0$, we deduce that $C = -\pi^2$. Thus
\(\displaystyle \dot{u}^2 = e^{2u} - \pi^2\)
\(\displaystyle \dot{u} = \pm \sqrt{e^{2u} - \pi^2}\)
\(\displaystyle \int \frac{du}{\sqrt{e^{2u} - \pi^2}} = \pm \int dt\)
\(\displaystyle \int \frac{du}{\sqrt{e^{2u} - \pi^2}} = \pm t + c\)
Letting $e^u = \pi \cosh v$, the integral on the left becomes
\(\displaystyle \frac{1}{\pi} \int \sech v\, dv = \frac{1}{\pi}\arccos(\sech v) + c = \frac{1}{\pi}\arccos(\pi e^{-u}) + c\)
Therefore
\(\displaystyle \frac{1}{\pi} \arccos(\pi e^{-u}) = \pm t + c\)
\(\displaystyle \pi e^{-u} = \cos(\pi t + c)\)
\(\displaystyle e^u = \pi \sec(\pi t + c)\)
Invoking the initial condition $u(1/2) = \log \pi$, we determine $c = -\pi/2$. Since $u = \log y$, we conclude
\(\displaystyle y = \pi \sec\left(\pi t - \frac{\pi}{2}\right) = \pi \csc(\pi t)\)
FAQ: Can This Differential Equation Be Solved with Given Initial Conditions?
What is a differential equation?
A differential equation is a mathematical equation that relates the rate of change of a function to the function itself. It involves derivatives and can be used to model the behavior of a system over time.
How do I solve a differential equation?
The method for solving a differential equation depends on its type. Some common techniques include separation of variables, integrating factors, and the method of undetermined coefficients. It is important to identify the type of differential equation and choose the appropriate method for solving it.
What are the applications of differential equations?
Differential equations are used in many fields of science and engineering to model and understand the behavior of systems. They are used to study population growth, chemical reactions, fluid dynamics, and many other phenomena.
Can all differential equations be solved analytically?
No, not all differential equations have analytical solutions. Some equations may require numerical methods or approximation techniques to find a solution. In some cases, it may not be possible to find a solution at all.
Why are differential equations important?
Differential equations are important because they provide a powerful tool for understanding and predicting the behavior of systems. They are used in many fields of science and engineering to make accurate predictions and inform decision making.
