Can this explain the double-slit experiment by a classical way?
In summary: Then you are proposing your own new theory. If you think you are able to do that, then you've ignored the PF Rules that you had agreed to. Please re-read it.
Windows
Hello.
I found it very strange that matter behave as a wave and started thinking a lot...
I have seen a video previously explaining this experiment and when I saw this:
In red is the first path and in blue the second path.
Could it be the answer?
At the end of the video, in the screen of the experiment, we can see two big lines and at the edges lines that goes lighter just like experiments using electrons.
Also the electrons are small, so if they collide with wall they would be a bigger pattern just like in the double-slit experiment.
No?
Thank you.
This is a common fallacy.
Remember that in the double slit experiment, the initial condition is IDENTICAL all the time, i.e. you have a monoenergetic beam with a very specific momentum. That's the idealized starting condition.
What this means classically is that all the "balls" can be aimed exactly at a particular location ALL THE TIME. I can hit that same slit and at the wall of the slit identically every single time! If that's the case, what do you think is the result after these balls passes through the slits? Do you think you'll get the same distribution?
Secondly, and this is crucial to understand especially if you are not in science. You simply cannot make a handwaving argument such as this. There must be some quantitative estimation of the result, i.e. you need to use some sort of a classical distribution and make a quantitative prediction on how the result will look like. Physics isn't just saying "what goes up must come down". It must also say "when and where it comes down". So for your proposal to be taken seriously, it MUST have that quantitative calculation. And for this case, you need to show what your initial momentum/energy distribution of the balls are, and then calculate the trajectory of these balls if they hit either one single spot on the slit, of multiple spots on the slits, and then show the distribution pattern on the screen.
Otherwise, it is a handwaving argument.
BTW, you might want to also consider how you would apply your scenario when I show you a similar interference pattern made by superconducting current when they pass through two different circuit branches. It is the identical experiment to the double slit. Or, use the Michaelson-Morley interferrometer where instead of two slits, you instead have a beam splitter that separates the beam into two different paths. Where is the equivalent "bounce off the slit walls" in those two examples?
Zz.
Also, if you actually simulate a "bouncing ball" system like this you will find that you will still not get anynthing similar to an interference pattern, unless you specify a VERY contrived initial distribution (not to mention the right width and thickness of the slits etc).
So no, it does not work.
A friend of my wrote a simulation like this as an excersise when we were undergraduates (I guess we must have been working on Monte Carlo techniques), I don't think it is available on the web anymore (this was 15 years ago); but there must be other applets out there that will do the same thing.
It do when I made a 2 dimensional simulation.
Also the wall is radiating electromagnetic radiation that we must include in account.
Zz.
Related to Can this explain the double-slit experiment by a classical way?
1. What is the double-slit experiment?
The double-slit experiment is a famous experiment in quantum mechanics that demonstrates the wave-particle duality of light. It involves passing a beam of light through two parallel slits and observing the interference pattern that is formed on a screen behind the slits.
2. How does the double-slit experiment relate to classical physics?
The double-slit experiment cannot be explained by classical physics, which assumes that light behaves solely as a particle. In the classical explanation, the light would pass through one of the slits and create a single bright spot on the screen. However, the actual experiment shows an interference pattern, which can only be explained by the wave-like nature of light in quantum mechanics.
3. Can the double-slit experiment be explained by classical physics?
No, the double-slit experiment cannot be fully explained by classical physics. The classical explanation can only account for the behavior of light as a particle, while the experiment clearly demonstrates the wave-like behavior of light.
4. Are there any attempts to explain the double-slit experiment using classical physics?
There have been attempts to explain the double-slit experiment using classical physics, such as the pilot wave theory. However, these explanations have not been widely accepted as they still cannot fully account for the observed interference pattern.
5. What is the significance of the double-slit experiment in quantum mechanics?
The double-slit experiment is significant because it provides evidence for the wave-particle duality of light, which is a fundamental concept in quantum mechanics. It also challenges our understanding of the behavior of matter and energy, and has led to further advancements in the field of quantum mechanics.
