Can This Infinite Series Be Summed?
In summary, MarkFL and Pranav have both provided elegant solutions to evaluate the sum $\dfrac{1}{3^2+1}+\dfrac{1}{4^2+2}+\dfrac{1}{5^2+3}+\cdots$ while also thanking Random Variable for contributing to the conversation.
anemone
MHB
POTW Director
3,883
115
Evaluate $\dfrac{1}{3^2+1}+\dfrac{1}{4^2+2}+\dfrac{1}{5^2+3}+\cdots$
Mathematics news on Phys.org
My solution:
\(\displaystyle S=\sum_{k=1}^{\infty}\left(\frac{1}{(k+2)^2+k} \right)=\sum_{k=1}^{\infty}\left(\frac{1}{(k+1)(k+4)} \right)\)
Using partial fraction decomposition on the summand, we find:
\(\displaystyle S=\frac{1}{3}\sum_{k=1}^{\infty}\left(\frac{1}{k+1}-\frac{1}{k+4} \right)\)
We may write this as:
\(\displaystyle S=\frac{1}{3}\left(\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+\sum_{k=1}\left(\frac{1}{k+4}-\frac{1}{k+4} \right) \right)\)
And so we have:
\(\displaystyle S=\frac{1}{3}\cdot\frac{13}{12}=\frac{13}{36}\)
MarkFL said:
My solution:
And so we have:
Hey MarkFL, your method is so elegant and neat!:cool: Well done, my sweet admin!
Notice that the given sum can be written as:
$$\sum_{r=1}^{\infty} \frac{1}{(r+2)^2+r}=\sum_{r=1}^{\infty} \frac{1}{r^2+5r+4}=\sum_{r=1}^{\infty} \frac{1}{(r+4)(r+1)}$$
$$=\frac{1}{3}\left(\sum_{r=1}^{\infty} \frac{1}{r+1}-\frac{1}{r+4}\right)$$
$$=\frac{1}{3}\left(\sum_{r=1}^{\infty}\int_0^1 x^r-x^{r+3}\,dx\right)=\frac{1}{3}\left( \sum_{r=1}^{\infty} \int_0^1 x^r(1-x^3)\,dx\right)$$
$$=\frac{1}{3}\int_0^1 (1-x^3)\frac{x}{1-x}\,dx = \frac{1}{3}\int_0^1 x(x^2+x+1)\,dx=\frac{1}{3}\int_0^1 x^3+x^2+x \,dx$$
Evaluating the definite integral gives:
$$\frac{1}{3}\cdot \frac{13}{12}=\frac{13}{36}$$
Hmm...another good method to solve this problem, thanks Pranav for the solution and also for participating!:)
You should thank Random Variable for this. :p
http://mathhelpboards.com/calculus-10/limit-sum-8576.html#post39742
I will...but, does this mean you are kind of "cheating" here? Hehehe...just kidding!:p
FAQ: Can This Infinite Series Be Summed?
What is the formula for evaluating the sum to infinity?
The formula for evaluating the sum to infinity is Sn = a / (1-r), where S is the sum, a is the first term, and r is the common ratio.
Can the sum to infinity be negative?
Yes, the sum to infinity can be negative. This happens when the common ratio is negative, causing the terms in the series to alternate between positive and negative values.
How do you know if the sum to infinity converges or diverges?
The sum to infinity converges if the absolute value of the common ratio is less than 1. It diverges if the absolute value of the common ratio is greater than or equal to 1.
What is the significance of evaluating the sum to infinity?
Evaluating the sum to infinity allows us to determine the total value of an infinite series. This can be useful in various fields of science, such as physics and economics.
Are there any real-life applications of evaluating the sum to infinity?
Yes, there are many real-life applications of evaluating the sum to infinity. For example, it can be used to calculate the total distance traveled by a moving object with a constant acceleration, or to determine the total value of an investment with compound interest.
