Can This Unique Pair of Values Solve the Equation?
In summary, solving a system of equations means finding the values of the variables that make all of the equations in the system true at the same time. There are several methods for solving a system of equations, including substitution, elimination, and graphing. The most appropriate method to use depends on the specific equations in the system. A consistent system of equations has at least one solution, meaning the equations intersect at one point. An inconsistent system has no solutions, meaning the equations do not intersect and are parallel. A system of equations can have one, infinite, or no solutions, depending on the specific equations and the number of variables in the system. Solving a system of equations is a fundamental tool in many fields and can be applied to real-life
anemone
MHB
POTW Director
3,883
115
Problem:
Solve the system:
$\displaystyle \sqrt{3x}\left(1+\frac{1}{x+y} \right)=2$
$\displaystyle \sqrt{7y}\left(1-\frac{1}{x+y} \right)=4\sqrt{2}$
Mathematics news on Phys.org
y=6x
x approaches 1.03
y approaches 6.18
in fact x is the solution of quadratic equation :
$147x^2-154x+3=0$
we delete the smaller solution
Albert said:
y=6x
x approaches 1.03
y approaches 6.18
$147x^2-154x+3=0$
I'm sorry Albert, I don't follow your reasoning at all...
We can express $$\left\{\begin{matrix}
\sqrt{3x}\left(1+\dfrac{1}{x+y}\right)=2\\ \sqrt{7y}\left(1-\dfrac{1}{x+y}\right)
=4\sqrt{2} \end{matrix}\right.\Leftrightarrow \left\{\begin{matrix} 1+\dfrac{1}{x+y}=\dfrac{2}{\sqrt{3x}}\quad (1)\\ 1-\dfrac{1}{x+y}=\dfrac{4\sqrt{2}}{\sqrt{7y}}\quad (2)\end{matrix}\right.$$ Using the transformations $(1)+(2)$ and $(1)-(2)$: $$\left\{\begin{matrix} 1=\frac{1}{\sqrt{3x}}+\frac{2\sqrt{2}}{\sqrt{7y}} \quad (3)\\ \frac{1}{x+y}=\frac{1}{\sqrt{3x}}-\frac{2\sqrt{2}}{\sqrt{7y}}\quad (4) \end{matrix}\right.$$ Multiplying $(3)$ by $(4)$: $$\frac{1}{x+y}=\frac{1}{3x}-\frac{8}{7y}=\frac{7y-24x}{21xy}\Leftrightarrow\ldots \Leftrightarrow 7y^{2}-38xy-24x^{2}=0\quad (5)$$ Solving the quadratic equation $(5)$ on $y$: $$y=\dfrac{38x\pm\sqrt{2116x^2}}{14}=\ldots=\{6x,-(4/7)x\}$$ Hence, we get $y=6x$ or $y=-\frac{4}{7}x$. Could you continue?
Albert said:
y=6x
x approaches 1.03
y approaches 6.18
$147x^2-154x+3=0$
Why do you start with $y=6x$?
Let x+y=A
we get :
$\sqrt{\dfrac{4}{3x}}=1+\dfrac{1}{A}$-----------(1)
$\sqrt{\dfrac{32}{7y}}=1-\dfrac{1}{A}$----------(2)
$(1)^2-(2)^2 :$
$\dfrac{4}{3x}-\dfrac{32}{7y}=\dfrac{4}{x+y}$
$\dfrac{1}{(x+y)}=\dfrac{(7y-24x)}{(21xy)}$
$24x^2+38xy-7y^2$=0
(4x+7y)(6x-y)=0
y=$\dfrac{-4x}{7}$ or y=6x
because x>0 and y>0
so y=$\dfrac{-4x}{7}$ does not fit
so we start with y=6x
That's great, Fernando!
And yes, I could continue from there...
From $7y^2-38xy-24x^2=0$, we factorize it (like what Albert did, to get $(y-6x)(7y+4x)=0$ and we find $y=6x$ or $y=-\frac{4}{7}$.
Since $x, y>0$, we're left with only $y=6x$ to consider with.
If we substitute $y=6x$ back into the equation $\displaystyle 1+\frac{1}{x+y}=\frac{2}{\sqrt{3x}}$and letting $k=\sqrt{x}$, we obtain:
$7\sqrt{3}k^2-14k+\sqrt{3}=0$
Now, use the quadratic formula to solve for k yields $\displaystyle k=\frac{7\pm 2\sqrt{7}}{7\sqrt{3}}$, thus, $\displaystyle x=(\frac{7\pm 2\sqrt{7}}{7\sqrt{3}})^2$ and $\displaystyle y=6(\frac{7\pm 2\sqrt{7}}{7\sqrt{3}})^2$.
according to your post , you have two solutions,but one of the combinations
will make $1-\dfrac{1}{x+y}<0$ ,this combination
should also be deleted
will make 1-1/(x+y) <0 ,this combination
You're right, Albert! I didn't check and verify the answer. :eek: Thanks for letting me know about this.
We have only one pair of value that satisfies the given equations...and they're
$\displaystyle x=(\frac{7+ 2\sqrt{7}}{7\sqrt{3}})^2$ and $\displaystyle y=6(\frac{7+ 2\sqrt{7}}{7\sqrt{3}})^2$.
FAQ: Can This Unique Pair of Values Solve the Equation?
What does it mean to "solve a system of equations"?
Solving a system of equations means finding the values of the variables that make all of the equations in the system true at the same time.
How do you solve a system of equations?
What is the difference between a consistent and an inconsistent system of equations?
Can a system of equations have more than one solution?
Yes, a system of equations can have one, infinite, or no solutions. This depends on the specific equations and the number of variables in the system.
How can solving a system of equations be applied in real life?
Solving a system of equations is a fundamental tool in many fields, including science, engineering, economics, and even everyday life. It can be used to model and solve real-world problems such as finding the optimal mix of ingredients in a recipe or determining the best route for a road trip.
