Can this work as a basis for S?
In summary: Polynomials? Equations? Vectors?I'm sorry if I was not very clear but in very beginning I wrote that "n is fixed"In summary, the conversation discusses finding a basis for a set ##S## of polynomials of degree less than or equal to a fixed value ##n##, which also satisfy the condition ##p(0)=p(1)##. The possible bases for ##S## are discussed, with the conclusion that a basis can be found by determining a set of linearly independent polynomials that satisfy the closure axioms. It is mentioned that the set ##A##, defined as ##A = \{1\}##, is not a suitable basis for ##S
Hall
351
87
Let ##S## be a set of all polynomials of degree equal to or less than ##n## (n is fixed) and ##p(0)=p(1)##.
Then, a sample element of ##S## would look like:
p(t) = c_0 + c_1t +c_2t^2 + \cdots + c_nt^n
Now, to satisfy ##p(0)=p(1)## we must have
\sum_{i=1}^{n} c_i =0
What could be the possible bases for S? I thought of one of them and it looks like this
A = \{ 1, c_1t +c_2t^2, c_1t +c_2t^2+c_3t^3, \cdots c_1t +c_2t^2 ... +c_nt^n | \sum_{i=1}^{j} c_i =0 ; j=1,2,3 ... n\}
Is A a basis for S? I mean, I'm unable to disprove it.
That solution is not very explicit. You really want to find ##n## explicit, linearly independent polynomials.
What do you have to check, in order to prove that ##S## is a subspace?
S should be a subset of a linear space of all polynomials of degree equal to or less than n and S should satisfy closure axioms.
Yes. You don't need a basis, you only have to show that ##p(x)+q(x)\, , \, \lambda p(x) \in S## whenever ##p(x),q(x) \in S## and ##\lambda \in \mathbb{F}## whatever the scalar field ##\mathbb{F}## is.
Yes, but I wanted to find a basis for S.
In which case you must be more specific. E.g. you defined ##A=\{1\}## which is only a basis for ##n=1.##
And after you have found polynomials which are not all zero, then you still have to prove linear independence and determine the dimension of ##S.##
I wrote that S is a set of all polynomials of degree ##\leq n## and ##p(0)=p(1)## for all p(t) belonging to S. And A is not a singleton set. ##p(t)=1## does satisfy the qualifications for belonging to S.
You must have misread post #1, in which he wrote the above.
You must have failed to solve the linear equation system.
I'm not sure where this thread is going. A basis is a set of specific vectors. It's not a set of equations.
The definition of ##A## is ##A=\{1\}##.
What the OP wanted to define is
A = \{ 1, c_1^{(1)}t +c_2^{(1)}t^2, c_1^{(2)}t +c_2^{(2)}t^2+c_3^{(2)}t^3, \cdots c_1^{(n-1)}t +c_2^{(n-1)}t^2 ... +c_n^{(n-1)}t^n | \sum_{i=1}^{j} c_i^{(k)} =0 ; j=1,2,3 ... n;k=1,\ldots,n-1\}
which still is an infinite set of vectors.
All right, let me once again try to make myself clear.
##S## is a set of all polynomials of degree ##\leq n## which satisfy the following condition
p(0)=p(1)
Find a basis for S.
p(0)=p(1)
Find a basis for S.
I understand that. You need to find a suitable set of polynomials.
Just wanted to clear, "A basis is a set of specific vectors" or "A basis is a set of specific mathematical objects" ?
##A## is ill-defined! See post #12. You defined all ##c_j=0##.
I wrote the sum of c_i's to be zero.
If we are talking about a basis for a vector space, then the appropriate mathematical objects are vectors. Although, in this case the vectors are polynomials.
Vectors are polynomials?
Read post number 12.
Let's leave my A, and start afresh for finding a basis for S.
The other way around: polynomials can be vectors.
You must understand how sets are defined! You used the same set of coefficients for all of your polynomials and that is a big mistake. Furthermore, you have to specify all ##2+3+\ldots + n## coefficients in order to specify a certain basis.
They can be. Specific examples of vector spaces are ##\mathbb R^n, \mathbb C^n##, sets of matrices, sets of linear operators, sets of polynomials, sets of functions. Sometimes a vector space generally is called a linear space. I would have thought that was all clear given your attempt at this problem!
Tom Apostol never uses the word vector space in his Calculus Vol 2, and I'm learning from that. He says linear space is a set of any mathematical objects that satisfy the axioms.
Likes PeroK
Okay. Now, I see the point of post 12. Is the treated form of A a basis for S?
https://en.wikipedia.org/wiki/Vector_space
Likes Hall
fresh_42 said:
Furthermore, you have to specify all ##2+3+…+n## coefficients in order to specify a certain basis.
What are the ##c_i##? E.g. all ##c_i=0## satisfy your choices but are not a basis.
Then you have to prove that ##\dim S =n## and linear independence of your selected polynomials.
fresh_42 said:
A is ill-defined! See post #12. You defined all cj=0.
##\sum_{i = 1}^n c_i = 0## doesn't necessarily mean that all of the constants ##c_i## must be zero.
For example, if n = 2, ##p(x) = 1x^2 - 1x## satisfies p(0) = 0 and p(1) = 0, and ##\sum_{i = 1}^n c_i = 0##.
  • #31
That was not what he wrote (see post #1). His definition implied all ##c_i=0.## If ##j=1,2,\ldots,n## is written in the definition of a set, it usually means for all ##j.##
  • #32
I disagree. Here's what he wrote in post #1.
He did ***not** write ##c_i = 0, i \in \{1, \dots, j\}##. Rather it was the sum of the ##c_i##.
  • #33
It does not matter how often you repeat it. Wrong remains wrong. The upper limit of the sum is ##j##, not ##n##. Please be precise if you quote others.
\begin{align*}
\begin{bmatrix}
1&1&\ldots&1\\
0&1&\ldots&1\\
0&0&\ldots&1\\
&\vdots&\ddots&\\
0&0&\ldots&1\\
\end{bmatrix}
\end{align*}
is a regular matrix.
  • #34
Then what the OP wrote was at least ambiguous. The first summation he wrote was ##\sum_{i = 1}^n c_i = 0##, which is what I was focused on. In the second summation, I don't believe he intended for all of the constants to be zero.
What I believe he was trying to get across was a set something like this: ##\{x^2 - x, x^3 - 2x^2 + x, \dots \}##. Including 1 in the set as he did violates the conditions that p(0) = p(1) = 0
  • #35
Mark44 said:
What I believe he was trying ...
This is irrelevant. He made a definition error by defining ##A## and I pointed this out. It is important to learn how to write sets. I even explained it in detail in post #12. Guessing what could have been meant is ineffective.
Likes PeterDonis
  • Linear and Abstract Algebra
