Can three tangents to a circle meet at a common point?
  • MHB
  • Thread starter poissonspot
  • Tags
    Circle
In summary, the conversation discusses finding two tangent lines to a circle passing through a given point outside of the circle. The participants consider using a unit circle and a point on the y-axis, and discuss the equations and solutions for the tangent lines. The conversation also mentions using vector algebra as an approach to solving the problem.
poissonspot
40
I considered the question of whether three tangents to the circle could meet at a common point and only came up with a contradiction by lengthy constructive means.
Circles are "nice", so there must be some clever ways of showing this fact that given a point outside the circle there are two tangent lines to the circle passing through this point. Any ideas? Thanks mucho,
Mathematics news on Phys.org
You could, without loss of generality, use a unit circle, and a point on the $y$-axis outside of the circle $(0,b)$ where $1<b$.
The equation of the circle is:
\(\displaystyle x^2+y^2=1\)
The equation of the tangent lines is:
\(\displaystyle y=mx+b\)
Substitute for $y$ from the line into the circle:
\(\displaystyle x^2+(mx+b)^2=1\)
\(\displaystyle x^2+m^2x^2+2bmx+b^2=1\)
\(\displaystyle \left(m^2+1 \right)x^2+(2bm)x+\left(b^2-1 \right)=0\)
Now, by analyzing the discriminant, we find:
\(\displaystyle \Delta=(2bm)^2-4\left(m^2+1 \right)\left(b^2-1 \right)\)
\(\displaystyle \Delta=4\left(b^2m^2-b^2m^2+m^2-b^2+1 \right)\)
\(\displaystyle \Delta=4\left(m^2-b^2+1 \right)\)
We see that with $1<b$, there will be two real values of $m$, given by:
\(\displaystyle m=\pm\sqrt{b^2-1}\)
This implies there are two tangent lines:
\(\displaystyle y=\pm\sqrt{b^2-1}x+b\)
Thanks, this is close to how I approached the problem. I used vector algebra though instead and solved for points where the dot product was equal to zero.
btw, I'm still interested in other solutions if anyone else is. Thx again,
FAQ: Can three tangents to a circle meet at a common point?
What is a tangent to a circle?
A tangent to a circle is a line that touches the circle at exactly one point, called the point of tangency. This point is also perpendicular to the radius of the circle at that point.
How many tangents can a circle have?
A circle can have an infinite number of tangents. This is because any line that passes through the center of the circle will be perpendicular to the radius at that point and therefore will be a tangent to the circle.
Can a tangent and a radius of a circle be parallel?
No, a tangent and a radius of a circle cannot be parallel. This is because a tangent is always perpendicular to the radius at the point of tangency. If they were parallel, they would never intersect at a single point.
How do you find the length of a tangent to a circle?
The length of a tangent to a circle can be found using the Pythagorean Theorem. If the tangent and radius of the circle form a right triangle, the length of the tangent can be calculated by taking the square root of the difference between the length of the radius and the distance from the center of the circle to the point of tangency squared.
Can a tangent to a circle intersect the circle at more than one point?
No, a tangent to a circle can only intersect the circle at one point, the point of tangency. This is because the tangent is defined as a line that touches the circle at exactly one point.
