I Can trains use permanent magnets to be propelled?
A discussion on the feasibility of using permanent magnets for propulsion in trains, particularly maglev trains, concluded that such a system would violate the first law of thermodynamics. The referenced article about a maglev train claims to operate "power-free," but this is misleading, as the train uses permanent magnets solely for lifting, not propulsion. Critics argue that the article manipulates facts to suggest a perpetual motion-like system, which is impossible. The train's design reportedly allows for energy savings in suspension but does not eliminate the need for power in propulsion. Overall, the consensus is that while permanent magnets can assist in levitation, they cannot provide continuous propulsion without an external energy source.
Suekdccia
TL;DR Summary
No, that would be a violation of the first law of thermodynamics. The article is most likely just badly written and the train only uses the permanent magnets for lifting.
Likes vanhees71
What russ said.
Levitated, sure; propelled no.
The article is very manipulative. It says "...runs power-free...", and "...takes electricity out of the equation, using only magnets composed of rare-earth metal..."
But the veeerrrry last sentence in the article is a quote by an engineer that says:
"Its most prominent feature is zero-power suspension, which can save at least 31% of the energy normally needed to suspend trains using previous electromagnetic levitation technology,’ "
This is the internet in the 21st century. If it can be staged, faked or Photoshopped, it surely is staged, faked or Photoshopped.
Likes berkeman, vanhees71, russ_watters and 1 other person
Asked and answered. Thank you all. :smile:
Likes Bystander and vanhees71
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
