Can we add or remove a proton?
  • Thread starter kenewbie
  • Tags
    Proton
In summary, the conversation discusses the possibility of removing or adding protons from atoms to create new elements. It is confirmed that this has been done in a lab, with the first successful transmutation occurring in 1919 by Ernest Rutherford. There is also discussion about the potential use of transmutation in nuclear reactors and the history of the term "transmutation." There is mention of a paper by Rutherford from 1911 and a question about the rest masses of the particles involved in transmutation.
kenewbie
239
Have we successfully removed a proton from an atom, or added one? Can we take mercury and remove a proton, or add one to platinum, and so make gold?
Has this been done in a lab?
k
Isn't this is what we do in nuclear fission/fusion [atom bomb etc.]? But I think adding or removing just one proton might be very hard.
I thought the atom bomb relied on neutrons, not protons? A neutron does not loose momentum or deflect as it approach it's target, since it has no charge, and that when the atom splits it releases new neutrons?
k
But when the atom splits, the nucleous divides into pieces so in that sense the atom has also lost protons. But, of course, the nucleous has to be very unstable to begin with. I don't know anyway to remove just one proton or how to remove anything from the nucleous of stable atoms.
This has already been done as far back as 1919. Ernest Rutherford then transmuted nitrogen gas into oxygen by bombarding it with alpha particles.
[PLAIN]http://www.stmary.ws/physics/amsco_review_and_glencoe/chapter05.pdf said:
The[/PLAIN] first artificial transmutation of one element to another was performed by Rutherford in 1919. Rutherford bombarded nitrogen with energetic alpha particles that were moving fast enough to overcome the electric repulsion between themselves and the target nuclei. The alpha particles collided with, and were absorbed by, the nitrogen nuclei, and protons were ejected. In the process oxygen and hydrogen nuclei were created.
See http://en.wikipedia.org/wiki/Nuclear_transmutation for more details.
Likes 1 person
I did not know that!
Yes, it's surprising that something as apparently groundbreaking as this is rarely known. I myself didn't learn of this by reading either a textbook or a short biography of Rutherford. I was reading a book which contained the author's summary of the history of science since the Ancient Greeks and chanced upon Rutherford's 1919 discovery when the author was discussing the supposedly dead concept of transmutation.
k
While I'm uncertain whether this has been done or not I'm pretty sure that part of the work of some particle accelerators is to fabricate certain materials with specific isotopes in them. Whether we can pick and choose which atoms we can and have added a single proton is unknown to me. However I believe I can find out from someone who works in that field. I'll check and get back to you.
Pete
What happens with the energy and the energy after in this case? Does the change produce any heat to make a small nuclear reactor out of it?
I like this bit in the wikipedia entry:
> At the moment of realization, Soddy later recalled, he shouted out: "Rutherford, this is transmutation!" Rutherford snapped back, "For Christ's sake, Soddy, don't call it transmutation. They'll have our heads off as alchemists."
Well said. A pioneer must remember to either keep his mouth shut, or phrase profound discoveries in a way that doesn't invite the attention of dogmatic thinker thought police.
Most transmutations are too inefficient to power a reactor, but there are concepts for transmuation using proton accelerators as in Accelerator Driven systems for transactinide transmutation.
Transmutation is the appropriate word for what Rutherford and other did, but it carried a somewhat negative context in that day and time. Rutherford could have been joking as well.
Rutherford's paper of 1911 (or at least a transcription).
http://www.lawebdefisica.com/arts/structureatom.pdf
I believer Rutherford used Ra or Po as a source of alpha particles.
Is there any table of the rest masses of all the objects involved here?
Related to Can we add or remove a proton?
1. Can we add a proton to an atom?
Yes, it is possible to add a proton to an atom through a process called protonation. This can occur in chemical reactions where a proton is transferred from one molecule to another, resulting in the formation of a new compound.
2. Can we remove a proton from an atom?
Yes, it is possible to remove a proton from an atom through a process called deprotonation. This can also occur in chemical reactions where a proton is transferred from one molecule to another, resulting in the formation of a new compound.
3. What happens when we add a proton to an atom?
When a proton is added to an atom, the atom becomes positively charged, as the number of protons now exceeds the number of electrons. This can result in changes in the atom's chemical and physical properties.
4. What happens when we remove a proton from an atom?
When a proton is removed from an atom, the atom becomes negatively charged, as the number of electrons now exceeds the number of protons. This can also result in changes in the atom's chemical and physical properties.
5. Are there any limitations to adding or removing protons from an atom?
There are limitations to adding or removing protons from an atom. The atomic number of an element, which is determined by the number of protons in its nucleus, cannot be changed without changing the element itself. Additionally, adding or removing protons can significantly alter the stability and reactivity of an atom.
  • Classical Physics
