MHB Can We Alter the Color of Leaves? - MonkeySee.com
  • Thread starter Thread starter yakin
    Color
Leaves appear green because they reflect green light and do not absorb it. If the biological or chemical properties of a leaf are altered to prevent it from absorbing green light, the leaf would reflect other wavelengths, resulting in a different color. The discussion emphasizes that changing these properties could lead to leaves appearing in colors that correspond to the light they reflect. This concept hinges on the relationship between light absorption and reflection in plant biology. Ultimately, altering a leaf's properties could change its perceived color significantly.
yakin
42
I was watching the video on youtube provided by monkeysee.com explaining the reason we see leaf green is because it does not absorb green light hence reflects green light to our eye.
So it means if some how we change the biological/chemical properties of a leaf we won't see it as green? In other words we make leaf not absorb the green light then what?
Mathematics news on Phys.org
That's right. It would appear to be whatever color isn't absorbed.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation has no solutions with positive integers if It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
