KingNothing
- 881
- 4
Can we really measure a physical property of something, without changing it in any way at all?
The only counter-examples I can think of involve comparing the behavior of something to a "known value", such as holding a ruler up to an object or measuring mass with a balanced scale.
I believe there is a theorem (perhaps part of information theory) that essentially states that no transfer of information can occur without some transfer or change in energy. I don't remember what it's called or where to find it stated more eloquently.
- In a circuit, you cannot use a voltmeter to measure a voltage without changing the circuit. The change may be small or negligible in most cases, but it is there.
- If you use a thermometer to measure the temperature of a sample, the thermometer has had to absorb/dissipate some heat from/to the sample in order to read a change on the thermometer, thus changing it.
- A common "measurement" procedure for measuring an electric field is to place test charges within it, and absorb the effect. However, the addition of these charges does in fact changing the local electric field, as charges have fields of their own
- Quantum cryptography is based entirely on this concept - that measuring the information (reading it) would change its value
