- #36
miggidy
- 1
What about instead of building a structure to dissipate static electricity, to instead run a weather balloon (or blimp) with a long line attached to the ground. Could that perhaps serve as a cheaper alternative to capturing the static in the clouds?
chroot said:From an electrical engineering perspective, the hardest part about capturing the energy in a lightning strike is indeed its very swiftness. You're probably aware that batteries must be charged very slowly; all batteries have some unavoidable series resistance, and trying to pump tens of thousands of amperes of current through even a tiny resistance will still generate an enormous amount of heat -- enough to essentially fry the battery.
If you really wanted to capture the energy in lightning, you wouldn't want wait until a bolt occurs -- that's just too much current in too short a period of time. Instead, you could conceivably build a tall vertical structure which is capable of continually neutralizing static charge between cloud and ground. This structure could move the same amount of charge as in a lightning bolt, but spread over a much longer period of time. A current of tens of hundreds of amperes is quite easy to deal with, and could be used to charge ultracapacitors, spin up flywheels, etc.
Building such a tower would be an engineering feat, however, and it's not clear to me (I'd need to do some calculations) that the economic value of the energy that could reasonably be captured this way would justify the cost of the structures.
- Warren
