Can we have modulo a negative number?
In summary, the conversation discusses the idea of using modulo for negative numbers. It is explained that in terms of factorisation and remainders, using modulo for negative numbers would not provide any new insights. It is also mentioned that the same goes for allowing negative numbers to be prime, as the ideals for positive and negative numbers are the same. Furthermore, it is noted that allowing negative numbers to be prime is often excluded due to the definition starting with "a number is prime if it is no unit and...". The conversation also touches on the topic of using negative bases in arithmetic, and the idea of equal rights for negative numbers to be considered prime numbers.
matqkks
285
Why can't we have modulo negative number? I have never seen this.
Mathematics news on Phys.org
You would simply have to define what you mean by it.
In terms of factorisation and remainders, everything can be seen with a positive divisor, so I wouldn't expect any new insights.
The same goes for allowing negative numbers to be prime.
Because a negative number ##-n=(-1)\cdot n## differs from its positive counterpart only by a unit, ##\varepsilon=-1##. So the ideals ##n\mathbb{Z}## and ##\varepsilon n\mathbb{Z}## are the same. This implies that the factor rings ##\mathbb{Z}[x]/n\mathbb{Z} = \mathbb{Z}_n = \mathbb{Z}[x]/\varepsilon n\mathbb{Z}## are equal, too. And as it makes no difference, it is a matter of convenience to choose the positive version. Otherwise the calculations were full of unnecessary signs.
Likes lavinia and PeroK
I don't see any conceptual difference between modulo of a positive versus negative integer. I am not sure if all computer languages would implement it. Perl does:
Integers 0..9 mod -3:
0 mod -3 = 0
1 mod -3 = -2
2 mod -3 = -1
3 mod -3 = 0
4 mod -3 = -2
5 mod -3 = -1
6 mod -3 = 0
7 mod -3 = -2
8 mod -3 = -1
9 mod -3 = 0
Likes Janosh89
0 mod -3 = 0
1 mod -3 = -2
2 mod -3 = -1
3 mod -3 = 0
4 mod -3 = -2
5 mod -3 = -1
6 mod -3 = 0
7 mod -3 = -2
8 mod -3 = -1
9 mod -3 = 0
I had been impressed, if it would have calculated the results in the standard representation, i.e. ##[0],[1],[2]##. This way its more an incidental result.
The essential point is really, that "up to units" is often dropped in the definitions, be it as sloppiness or because it is self-evident. As @PeroK mentioned
the situation with primes is the same: "up to units", because ##-3## is as prime as ##3## is. And that ##1## isn't a prime, is only because the definition starts with "A number is prime, if it is no unit and ..." It makes absolute sense to exclude units. E.g. nobody ever asked, whether the fundamental theorem of arithmetic is wrong, since we can always add units as many as we want to: ##6=2\cdot 3= 1\cdot 2\cdot 3= (-1)\cdot (-1)\cdot 2 \cdot 3 = 1\cdot 1\cdot 3\cdot 2\cdot 1 =\ldots ## Units simply don't change the game, so why bother them?
Modular arithmetic sets up equivalences between negative numbers (the additive inverse) and positive numbers. -3 mod 3 = 0; -2 mod 3 = 1; -1 mod 3 = 2; etc. Modulo 3 and modulo -3 works out to be consistant:
-4 mod 3 = 2
-3 mod 3 = 0
-2 mod 3 = 1
-1 mod 3 = 2
0 mod 3 = 0
1 mod 3 = 1
2 mod 3 = 2
3 mod 3 = 0
4 mod 3 = 1
-4 mod -3 = -1
-3 mod -3 = 0
-2 mod -3 = -2
-1 mod -3 = -1
0 mod -3 = 0
1 mod -3 = -2
2 mod -3 = -1
3 mod -3 = 0
4 mod -3 = -2
Sure. But this isn't evidence for a smart programming of Perl as you implicitly suggested, but simply a logic outcome of ordinary arithmetic. An automated conversion into standard results would have been smart. The above is more or less an unintended result of a correct division.
there is no reason for them to apologize for a "happy coincidence" that turns out to be mathematically correct.
Yes, but that's not the point. The point is, that similar to what led to the OP's question, the programmers completely ignored the role of units. In this sense, it is rather off-topic here than a support for the equation ##n\mathbb{Z}=-n\mathbb{Z}##. The example brought you no millimeter closer to the answer of the question. It only shows that you can do calculate with negative numbers, not why they are usually ignored in books.
IMO, in any algebra, -x is the additive inverse of x. x + (-x) = 0. I see no issue with units.
You can do arithmetic using negative bases for instance arithmetic base -2.
Because you confuse addition with multiplication. We are talking about multiplication here, since the module is ##z \,\,\cdot\,\, \mathbb{Z}\,##.
No ring, no question.
Given that it's the 21st century, perhaps mathematicians should be thinking about equal rights for negative numbers! Why should ##-5##, for example, be denied the right to be called a prime number, just because it was born on the wrong side of the number line?
Likes fresh_42
I guess I don't see the problem. It seems natural and uncomplicated to extend the equivalence classes in the non-negative integers defined by mod 3 ({0,3,6,9,...}, {1,4,7,10,...},{2,5,8,11,...}) to include the negative integers ({...,-9,-6,-3,0,3,6,9,...}, {...,-8,-5,-2,1,4,7,10,...},{...,-7,-4,-1,2,5,8,11,...}). Does this cause a problem when multiplication is introduced? Off-hand, I don't see it.
The female version of many professions is obtained by a suffix "in" in German, e.g. a female carpenter would be a carpenterin. This lead to thousandths of texts which are written with constructions like "... we are looking for a carpenter/in with at least five years of experience ..."
I see me writing: Let ##p/-p## be a prime. ...
However, in rings which have more than these two units, things will become quite disturbing: Let ##p/\varepsilon\cdot p## be a prime, where ##\varepsilon## is a unit, ...
No, it does not. It simply doesn't contribute anything to the answer of the question: Why are negative numbers ignored? It only shows, that the question has a justification, but nothing as to why this is the case.
Likes FactChecker
I had the same problem as the OP when I saw -1(MOD 10) on the OEIS site.
Centred 10-gonal numbers
A062786
no idea why the server cannot now find the site
The original OP question was "Why can't we have modulo negative numbers?". The answer is that we can. It is a natural extension of the concept to include negative integers. Then the OP asks why he has never seen it. The answer to that is that there is not much benefit.
modular constructions are defined modulo a subgroup, namely the subgroup generated by the integer given. Since n and -n generate the same subgroup, there is no difference whatsoever between modular arithmetic mod n and mod -n. To be precise, looking at the equivalence relation defining arithmetic mod n, divisibility by n is equivalent to divisibility by -n.
https://en.wikipedia.org/wiki/Quotient_group
Likes fresh_42
Related to Can we have modulo a negative number?
1. Can we have modulo a negative number?
Yes, it is possible to perform modulo on a negative number. Modulo is a mathematical operation that finds the remainder when one number is divided by another. It can be applied to both positive and negative numbers.
2. How does modulo work on negative numbers?
When performing modulo on a negative number, the result will always be a positive number. This is because the absolute value of the negative number is taken before finding the remainder. For example, if we have -10 mod 3, the absolute value of -10 is 10, and the remainder when dividing 10 by 3 is 1, so the result is 1.
3. Why is it important to be able to perform modulo on negative numbers?
Modulo is a fundamental operation in mathematics and has many applications in fields such as computer science, physics, and engineering. Being able to perform modulo on negative numbers allows for more efficient and accurate calculations and modeling of real-world phenomena.
4. Are there any limitations to performing modulo on negative numbers?
One limitation is that in some programming languages, the behavior of modulo on negative numbers may differ. For example, in Python, the result of -10 mod 3 is 2, while in Java, it is -1. It is important to check the specific language's documentation for the expected behavior.
5. Can negative numbers be used as the divisor in modulo?
Yes, negative numbers can be used as the divisor in modulo. The same rule applies where the absolute value of the negative number is taken before finding the remainder. For example, 10 mod -3 will result in a remainder of 1.
