Can we imagine that momentum is the total energy stored in the body at
In summary: In other words, if you have a body that is moving with a certain velocity, you have to expend an amount of effort to bring it to a stop.
amaresh92
163
can we imagine that momentum is the total energy stored in the body at a particular velocity?if not then why?
Not really, although they are related. The definition of momentum is
p = m v
while the kinetic energy of a body is
E = (1/2) m v2.
You may notice, if you know calculus, that p = dE/dv.
The second law of Newton is actually
F = dp/dt,
i.e. the force is the (instantaneous) change in momentum in time. When the mass of an object is constant, this reduces to F = ma.
Basically it expresses the ancient experimental fact that to move an object, not only the force that you extert determines the velocity it will get, but also the mass matters. In Egyptian terms, kicking a cat is easier than moving a pyramid :)
Momentum as far as I've read is best defined as the property of a body of mass M to move at a speed V given a certain impetus P. So the momentum stored in a body gives it the ability to move at a certain velocity. Kinetic Energy can be defined as the rate of translation of momentum or the measure of the amount of "activity" in a body due to its motion.
Momentum is related to the integral of a force over a time integral dt:
∫F dt = mv
Total energy is related to the integral of a force over a displacement dx:
∫F dx = ½mv2
Bob S
i could not understand your last sentence if i have commit any mistake theni am sorry for that.
What is possible is to derive conservation of momentum using only conservation of energy without invoking forces. Suppose we have in one frame of reference:
1/2 m1 v1^2 + 1/2 m2 v2^2 = 1/2 m1 v1'^2 + 1/2 m2 v2'^2
Here the velocities are vectors, square means inner product of the vector with itself. In another frame of reference moving with velocity U the conservation of energy equation reads:
1/2 m1 (v1-U)^2 + 1/2 m2 (v2-U)^2 =
1/2 m1 (v1'-U)^2 + 1/2 m2 (v2'-U)^2
f you expand out the squares, use conservaton of energy in the original frame and conservation of mass, you are left with the double inner product terms. Then noting that U is arbitrary, you are led to the conclusion that momentum is conserved.
You do not necessarily have to expend energy to bring a traveling body to a complete halt.
Nevertheless you have to apply effort to do this.
Momentum can be thought of as a measure the the amount of 'effort' required.
FAQ: Can we imagine that momentum is the total energy stored in the body at
1. What is momentum and how is it related to energy?
Momentum is a measure of an object's mass and velocity. It is related to energy because, according to the law of conservation of momentum, the total momentum of a system remains constant unless acted upon by an external force. This means that the total energy of the system, which includes both kinetic and potential energy, also remains constant.
2. Can momentum be converted into energy or vice versa?
Yes, momentum and energy are interchangeable in certain situations. For example, when an object is in motion, its momentum can be converted into kinetic energy. Similarly, when an object falls from a height, its potential energy is converted into kinetic energy.
3. Is momentum the same as total energy?
No, momentum and total energy are not the same. Momentum is a measure of an object's motion, while total energy includes both kinetic and potential energy. However, the two are related and can be converted into each other.
4. How is momentum conserved in a closed system?
In a closed system, the total momentum remains constant because there are no external forces acting on the system. This means that any change in momentum of one object must be balanced by an equal and opposite change in momentum of another object within the system.
5. Why is momentum important in understanding the behavior of objects?
Momentum is important because it helps us understand how objects move and interact with each other. It allows us to predict the motion of objects and explain phenomena such as collisions and explosions. Momentum is also a fundamental concept in physics and is essential in many scientific fields such as mechanics, thermodynamics, and electromagnetism.
