Can we measure absolute motion of Earth and Sun?
  • #36
I've been following this a little, and I think that is a possibility. (That he is considering relative motion of the two). What would happen if we slowed the solar wind down considerably, so that the earth's movement was clearly in a circular motion? Please ignore if my idea is irrelevant. I don't mean to interrupt the discussion.
  • #37
zasvitim said:
In some situations we will still get green particles yet don't get red particles because they bump into planet.
On the other side we should get red particles when sun is not visible already.
Now try to animate it like Ibix did, or create separate images for each of his frames, each with the current location of the signals and of the planet.
Likes Ibix
  • #38
That this is not what his animation in #2 shows, nor his words (see also the title and post #1), but all his still frames do.
You'd be able to detect that, yes. In an Earth centered frame fixed wrt the stars the Sun moves across the sky, so earlier and later emissions come from different places. What you cannot detect is inertial motion of the Sun/Earth center of mass, which is what the OP seems to be talking about.
  • #39
Ok, seems like I was wrong.
Yet there is a way to detect absolute motion. But it's of course out of this thread. And cannot be posted "unless peer reviewed" and can not be peer reviewed unless "agrees with everything".
  • Sad
  • Skeptical
Likes weirdoguy and PeroK
  • #40
It's OK to post questions, as to why something doesn't detect absolute motion. You only need peer reviewed references if you make claims.
  • #41
If there were such a thing it would show up as a violation of Lorentz covariance. People actively research this, and nothing has ever been found.
Given your struggles with frame changes in this thread, to put it bluntly it's a lot more likely that anything you submitted didn't pass peer review due to being directly self-contradictory.
Likes Dale and PeroK
  • #42
Lorentz transformation is about electromagnetic radiation. Some phenomena like heat may be excluded from it. Just an example: Why would there be much more cyclones in northern hemisphere if hemispheres are equal? Why equatorial counter current is in northern hemisphere etc.
  • #43
zasvitim said:
Just an example: Why would there be much more tornados in northern hemisphere if hemispheres are equal?
The Earth's hemispheres are definitely not equal. Compare the amount of landmass for example.
Likes Ibix and PeroK
  • #44
And how that "pushes" equatorial countercurrent?
  • #45
Land and water heat and cool at different rates. "Sea breeze by day; land breeze by night."
Likes Ibix
  • #46
You should start a new thread on this in an appropriate sub forum, if you cannot figure it out by own research.
Likes PeroK and Ibix
  • #47
No, it underlies literally every physical phenomenon - that it wasn't just about electromagnetism was the key insight Einstein made. Also you are completely missing the point: if he were wrong and Lorentz covariance were only about electromagnetism then violations of Lorentz covariance would be abundant. They aren't.
Likes Dale
  • #48
Just look at Earth: cyclones, currents, tidal waves in Canada.
  • #49
The Earth with asymmetric heat capacities has asymmetric weather distributions. This is not surprising.
  • #50
There is no any "sea breeze" in pacific ocean and it takes almost half of planet.
Yet the same phenomena: heated water finds itself in northern hemisphere.
As if there is some mechanism that "slows down" it and does not let freely move with the planet.
  • #51
So @zasvitim you're not here to learn, you're here to push you very basic misunderstandings.
Physics is an experimental science! Why all of people accusing physicists of some sort of conspiracies forget that? Absolute motion is refuted by milions of experiments and observations. Really, take your time to analise that, instead of wasting your (and ours) time. This is elementary and high-school physics, nothing advanced. Really.
Likes PeroK
  • #52
How am I not to learn if I accepted being wrong? I've accepted that, thank you.
Absolute motion is confirmed by directional light existence. And can be confirmed in experiment that will generate slow photons.
  • Sad
Likes weirdoguy
  • #53
Nonsense.
  • #54
weirdoguy said:
Nonsense.
Is this experimental science?
  • #55
Yes. See the aforementioned failure to detect violation of Lorentz covariance.
  • #56
Lorentz covariance could have absolutely different nature and have nothing to do with light.
For example it could be about mutually exclusive events:
Imagine that you are playing a game in which you have a sack of red and blue stones. You take a random stone out of the sack. If you get a red stone, you move to the right. If you get a blue stone, you draw a dash on a piece of paper. After that you put the stone back in the sack and mix the stones. You repeat this operation N times. At the end of the game, you measure how many steps you have taken and divide by the number of dashes. You call the result "speed".Let's say during the first game session you have 50 red stones and 50 blue stones in the sack. The probability of getting red and blue stones is the same, therefore the speed equals one.We put one additional red stone to the sack and play again. The probability of getting a red stone is now 51/101.At the same time, the probability of getting a blue stone has decreased. No it's 50/101. Thus, at the end of the game, we will not only take more steps to the right, but also find fewer dashes on the sheet. We divide the number of steps by the number of dashes and see that the dependence is not linear, but quadratic.We get Lorentz transformations.
  • Sad
  • #57
This thread is now closed. Thanks for everyone who tried to help.
Likes weirdoguy, Dale, Ibix and 2 others
