Can we prove the correspondence between a real number with a point ?
  • I
  • Thread starter fxdung
  • Tags
    Point
In summary, the conversation discusses the possibility of establishing a 1-1 correspondence between real numbers and points on a straight line in Euclidean geometry. It is mentioned that in some presentations of Euclidean geometry, lines are defined as images of 1-1 functions from the real numbers. However, in the original Euclidean geometry, it may not be possible to establish such a correspondence due to limitations in construction methods. The conversation also touches on the concept of constructible numbers and the development of Galois theory in understanding this concept.
fxdung
388
23
Can we prove that there is a corespondence 1-1 between a real number with a point of straight line?It seems to me that we can use Dedekin's cut to prove each point of line corresponds a real number. But how about the reverse?
Mathematics news on Phys.org
I am not sure, but a first step would be the definition of a point.
How can we definite a point in Euclide geometry?
That depends on how you define a straight line. More generally, it depends on what geometry you are using.
Some presentations of what we call Euclidean Geometry do so by effectively defining lines to be images of 1-1 functions from the real numbers, so in that case the answer is, almost trivially, Yes.
On the other hand, I think the original Euclidean geometry, using Euclid's original postulates, only allows construction of items that can be drawn on paper with a straightedge (ruler), pencil and collapsing compass (it collapses when you take either the pencil or the point off the paper). Many constructions cannot be done in such a geometry, such as trisecting an arbitrary angle. While we can construct line segments with square roots as lengths, and maybe even all algebraic numbers, I expect most transcendental numbers are impossible to construct. So we would be unable to establish a 1-1 correspondence between the real numbers and the points on a line in the original Euclidean geometry, because the latter provides no way to identify points whose distance from a given point on the line is a transcendental number.
If we define straight line to be image 1-1 of real number set, so in this geometry the 1-1 correspondence is a axiom, not a theorem?In elementary Euclid geometry,they do not define straight line but they image straight line as light ray. In this case the 1-1 correspondence is a axiom?
Yes to the first one - in that case the correspondence is given as an axiom.
No to the second case, which does not correctly represent Euclid's original postulates. He said nothing about light rays. In fact he does not even define lines or points, simply taking letting them be disjoint categories of unknown fundamental objects. What his axioms (he calls them postulates) do is attribute some properties to lines and points. Those properties are not sufficient to establish a correspondence between points on a line and the real numbers. They may be sufficient to establish a correspondence to some subset of the algebraic numbers, which are a proper subset of the real numbers, but I expect it would take a lot of work to construct one.
Typically we take it to be the intersection of two lines. So in Euclid's original geometry we cannot establish the existence of any points that we cannot construct as the intersection of two lines, using only the tools mentioned above.
Indeed, it's called the set of constructible numbers
https://en.m.wikipedia.org/wiki/Constructible_number
The set was only fully understood (though I think people basically knew what it would contain for much longer, proving it was impossible) in the 1800s with the development of Galois theory.
You can try by contradiction, assume that "there is a real number that is not in correspondence with a point on a line" ...
Ssnow
Related to Can we prove the correspondence between a real number with a point ?
1. Can we prove that every real number corresponds to a unique point on a number line?
Yes, this can be proven through the use of the decimal representation of real numbers. Each real number can be expressed as an infinite decimal, and each decimal point corresponds to a specific point on the number line. Therefore, every real number has a unique correspondence with a point on the number line.
2. How do we know that the correspondence between real numbers and points on a number line is accurate?
This correspondence is accurate because it follows the rules of mathematics and is consistent with the properties of real numbers. Additionally, it has been extensively studied and tested by mathematicians and has been proven to be accurate in various mathematical applications.
3. Is there a way to visually represent the correspondence between real numbers and points on a number line?
Yes, a number line is a visual representation of the correspondence between real numbers and points. Each point on the number line represents a specific real number, and the distance between points corresponds to the difference between those numbers.
4. Can we use this correspondence to compare the size of real numbers?
Yes, the correspondence between real numbers and points on a number line allows us to compare the size of real numbers. The further a point is from the origin on the number line, the larger the corresponding real number is.
5. Is there a limit to the accuracy of this correspondence between real numbers and points on a number line?
No, there is no limit to the accuracy of this correspondence. Real numbers can be expressed as infinitely precise decimals, and the number line can be extended infinitely in both directions, allowing for an infinite number of correspondences between real numbers and points.
  • General Math
  • General Math
