Can we use criss-cross approach with complex number equations?
In summary, the criss-cross approach, which involves multiplying both sides of an equation by the same number, is a valid step in solving equations with complex numbers. This approach can be used because of the field axioms, which state that any number (except for 0) multiplied by another number will result in an equivalent equation. However, it is important to note any restrictions, such as z≠−1, in order to avoid any invalid operations. It is recommended to test solutions in the original equation to ensure accuracy.
vcsharp2003
897
177
If ##\frac {z-1} {z+1} = ni## and ## Z\ne -1##, then can we simply criss-cross the denominators of the two sides so that LHS is multiplied by 1 and RHS is multiplied by ##z+1##? This is part of a bigger problem, but I just wanted to clear my doubts on whether this approach is possible.
None
I am not sure why criss-cross approach would work here, but it seems to get the answer. What would be the reason why we could use this approach?
$$\frac {z-1} {z+1} = ni$$
$$\implies \frac {z-1} {z+1} = \frac {ni} {1}$$
$$\implies {(z-1)} \times 1= {ni} \times {(z+1)}$$
It's easy to prove that ##{ab\over cd}=1\Leftrightarrow ab=cd## for complex numbers as well (cd##\ne 0##)
Likes vcsharp2003
So, the criss-cross approoach will work because of the result you mentioned.
Yes.
Likes vcsharp2003
vcsharp2003 said:
Homework Statement:: If ##\frac {z-1} {z+1} = ni## and ## Z\ne -1##, then can we simply criss-cross the denominators of the two sides so that LHS is multiplied by 1 and RHS is multiplied by ##z+1##? This is part of a bigger problem, but I just wanted to clear my doubts on whether this approach is possible.
Relevant Equations:: None
"Criss-cross" approach, as a term, seems less useful to me than what it is that you're actually doing. IOW, you're multiplying both sides of the given equation by ##z + 1##. This is guaranteed to be a valid step because it is given that ##z \ne -1##.
Multiplication of both sides of an equation, whether real or complex, is a property of equations that results in an equivalent equation, provided that what you multiply by is nonzero.
Likes vcsharp2003
Yes, I think your explanation is very logical. If two equals are multiplied by the same number (##\ne 0##), then they are still equals.
This multiplication is always allowed, even in the case ##z=-1.## Whether it makes sense is a different question. The important parts of the field axioms in this context are ##1\neq 0## and all ##z\ne 0## have a multiplicative inverse.
fresh_42 said:
This multiplication is always allowed, even in the case z=−1. Whether it makes sense is a different question.
Certainly multiplication of both sides of an equation by zero is allowed, but this operation isn't useful and doesn't produce a new equation that is equivalent to the one you started with. I made this clear in the next paragraph of what I wrote.
Yes, with complex numbers, you can do all the mathematical manipulation that you are used to with real numbers. In fact, you can do more. But the consequences are profound and worth a lot of study.
As always, when you cross-multiply you should be careful to keep track of things like ##z \ne -1## where the original equation was not allowed to divide by zero. Don't lose track of those things.
Likes vcsharp2003
In fact, it is often best to just go back and test any solutions in the original equations. Keeping perfect track of which values are illegal can get overwhelming. But in simple cases, it is best to keep track as the calculation proceeds.
Likes vcsharp2003
FAQ: Can we use criss-cross approach with complex number equations?
Can we use the criss-cross approach with complex number equations?
Yes, the criss-cross approach can be used with complex number equations. This method involves multiplying the numerators and denominators of two fractions to find the product.
What is the criss-cross method?
The criss-cross method is a technique used to multiply fractions. It involves multiplying the numerators and denominators of two fractions to find the product.
Is the criss-cross method applicable to all types of fractions?
Yes, the criss-cross method can be applied to all types of fractions, including complex number fractions.
How do you use the criss-cross method with complex number equations?
To use the criss-cross method with complex number equations, you simply multiply the numerators and denominators of the fractions as you would with regular fractions. The only difference is that you will be working with complex numbers instead of real numbers.
Are there any special rules or considerations when using the criss-cross method with complex number equations?
No, there are no special rules or considerations when using the criss-cross method with complex number equations. The same steps and principles apply as with regular fractions.
