FantasyQueen
- 7
Do many scientists believe in the existence of wormholes? Can further research lead to the invention of the time machine?
Nabeshin said:Pretty much no serious scientist believes that there exist naturally occurring wormholes out there somewhere. However, if you do have a wormhole, it is really quite trivial to construct a time machine from it from the following procedure:...
Phrak said:As measured in the relatively flat background metric of the universe, it takes an infinite amount of time to transit the event horizon.
Wormholes which could actually be crossed, known as traversable wormholes, would only be possible if exotic matter with negative energy density could be used to stabilize them. (Many physicists such as Stephen Hawking, Kip Thorne, and others believe that the Casimir effect is evidence that negative energy densities are possible in nature). Physicists have also not found any natural process which would be predicted to form a wormhole naturally in the context of general relativity, although the quantum foam hypothesis is sometimes used to suggest that tiny wormholes might appear and disappear spontaneously at the Planck scale.
Chronos said:I would say it takes imaginary energy to hold a wormhole open - emphasis on imaginary.
Phrak said:Yes, but we have plenty of that sort of stuff lying around lately, called dark matter and dark energy.
Currently, the existence of wormholes is still a theoretical concept and has not been proven. However, some equations in Einstein's theory of general relativity suggest that they could exist under certain conditions.
Wormholes are believed to be created through a process called "wormhole creation." This involves a highly dense region in space, such as a black hole, creating a tunnel through space-time that connects two distant points.
There is currently no evidence to suggest that wormholes can be used for time travel. However, some theories suggest that if it were possible to control and stabilize a wormhole, it could potentially be used to travel through time.
Wormholes are believed to have two ends, an entrance and an exit. The entrance is called the "mouth" and the exit is called the "throat." These ends are connected through the tunnel, allowing for travel between the two points.
As wormholes are still a theoretical concept, it is impossible to determine the safety of traveling through them. However, it is believed that the intense gravitational forces and radiation near the mouth of a wormhole could make it dangerous for human travel.
