Can xyz Exceed 1 Given x^2 + y^2 + z^2 + xyz = 4?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, when proving $xyz\le 1$ in non-negative reals, we use algebraic manipulation to show that the maximum value of $xyz$ is 1, which occurs when $x=y=z=1$. Non-negative reals are any real numbers that are greater than or equal to zero, including positive numbers, zero, and 0.5. This proof can be visualized by graphing the given equation and has applications in economics and physics. The implications of this proof include a better understanding of constraints and the ability to optimize processes. It can also be used in further mathematical proofs and equations related to non-negative reals.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
If $x,\,y$ and $z$ are non-negative reals such that $x^2+y^2+z^2+xyz=4$, prove that $xyz\le 1$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. kaliprasad
2. lfdahl
Solution from kaliprasad:
Using the AM-GM inequality
$x^2+y^2+z^2 \ge 3\sqrt[3]{(xyz)^2}$
so $x^2+y^2+z^2+xyz\ge 3\sqrt[3]{(xyz)^2} + xyz $
hence $3\sqrt[3]{(xyz)^2} + xyz \le 4$
$3\sqrt[3]{a^2} + a \le 4$ where $a= xyz$ and from the given condition $a\ge 0$, we can say $3\sqrt[3]{a^2} + a$ is monotically increasing and at $a= 1$ we have $3\sqrt[3]{a^2} + a = 4$.
$\therefore 3\sqrt[3]{a^2} + a \le 4$ occurs at $a\le 1$ or $xyz \le 1$. (Q.E.D.)
FAQ: Can xyz Exceed 1 Given x^2 + y^2 + z^2 + xyz = 4?
1) How do you prove $xyz\le 1$ in non-negative reals?
In order to prove this statement, we first need to understand the given conditions. We know that the numbers x, y, and z are non-negative and satisfy the equation $x^2+y^2+z^2+xyz=4$. We can then use algebraic manipulation to show that $xyz\le 1$. By substituting the value of $x^2+y^2+z^2$ from the given equation, we get $xyz\le 4-xyz$. From here, we can see that the maximum value of $xyz$ is 1, which occurs when $x=y=z=1$.
2) What are the non-negative reals?
Non-negative reals are any real numbers that are greater than or equal to zero. This includes positive numbers, zero, and the number 0.5.
3) Can you provide a visual representation of this proof?
Yes, we can visualize this proof by graphing the given equation $x^2+y^2+z^2+xyz=4$. The graph will be a sphere with radius 2 centered at the origin. The non-negative reals will be represented by the points on or inside this sphere. From here, we can see that the maximum value of $xyz$ is 1, which occurs at the point (1,1,1).
4) How does this proof relate to real-life applications?
This proof can be applied to various real-life scenarios, such as in economics or physics. For example, in economics, this proof can be used to show the relationship between the inputs and outputs of a production process. In physics, this proof can be used to explain the limitations of certain physical systems.
5) What are the implications of this proof?
The implications of this proof are that there is a maximum value of $xyz$ when the given conditions are satisfied. This can help us better understand the constraints and limitations of a system, and can also be used to optimize certain processes. Additionally, this proof can be used in further mathematical proofs and equations related to non-negative reals.
