Can you convert (s+1) to (u-2) in the integration of (3+s)^(1/2)(s+1)^2ds?
So, \((s+1)^2=(u-2)^2\).Does that make sense? :)In summary, the conversation discusses two methods for solving the integral ∫(3+s)1/2(s+1)2ds. The first method involves making a substitution u=s+3 and then expanding, distributing, and applying the power rule. The second method involves rewriting the integrand in terms of u=s+3 and then using integration by parts. Both methods lead to the solution of the integral.
paulmdrdo1
385
3.) ∫(3+s)1/2(s+1)2ds
I would let:
\(\displaystyle u=s+3\,\therefore\,du=ds\)
and now we have:
\(\displaystyle \int u^{\frac{1}{2}}(u-2)^2\,du\)
Now, expand, distribute, and then apply the power rule term by term.
MarkFL said:
I would let:
and now we have:
how do you get (u-2)2?
Hi everyone, :)
An alternative method without using substitutions is to write the integrand only using \(s+3\).
\begin{eqnarray}
\int(s+3)^{1/2}(s+1)^2\,ds&=&\int(s+3)^{1/2}(s+3-2)^2\,ds\\
&=&\int(s+3)^{1/2}\left((s+3)^2-4(s+3)+4\right)\,ds\\
&=&\int(s+3)^{5/2}\,d(s+3)-4\int(s+3)^{3/2}\,d(s+3)+4\int(s+3)^{1/2}\,d(s+3)\\
\end{eqnarray}
Hope you can continue. :)
Hi paulmdrdo, :)
The \(s+1\) in the integrand becomes \(u-2\). That is, \(u=s+3\Rightarrow u-2=s+1\).
FAQ: Can you convert (s+1) to (u-2) in the integration of (3+s)^(1/2)(s+1)^2ds?
What is the general process for integrating a polynomial 2?
The general process for integrating a polynomial 2 is to first rewrite the polynomial in standard form, with the terms arranged in descending order by degree. Then, use the power rule for integration, which states that the integral of x^n is (x^(n+1))/(n+1), to integrate each term separately. Finally, add any constants of integration to the result.
Can you provide an example of integrating a polynomial 2?
Yes, for example, to integrate the polynomial 2x^3 + 5x^2 + 2x + 7, we would first rewrite it as 2x^3 + 5x^2 + 2x + 7 = (2x^3) + (5x^2) + (2x) + (7). Then, using the power rule, we would integrate each term separately to get (2x^4)/4 + (5x^3)/3 + (2x^2)/2 + 7x + C, where C is the constant of integration.
Are there any special cases to consider when integrating a polynomial 2?
Yes, there are a few special cases to consider when integrating a polynomial 2. First, if the polynomial contains a constant term, such as 7 in the example above, it will simply be integrated as 7x. Additionally, if the polynomial contains negative exponents, they will need to be rewritten as positive exponents before using the power rule.
What is the difference between definite and indefinite integration of a polynomial 2?
The main difference between definite and indefinite integration of a polynomial 2 is that definite integration involves finding the exact value of the integral within a specified range, while indefinite integration involves finding a general formula for the integral without specifying a range. In other words, definite integration results in a numerical value, while indefinite integration results in a function.
How can integration of a polynomial 2 be used in real-life applications?
Integration of a polynomial 2 has many real-life applications, including in physics, engineering, and economics. For example, in physics, integration of an object's acceleration can be used to find its velocity, and integration of its velocity can be used to find its position. In economics, integration can be used to find the total revenue or profit of a business over a given time period. Additionally, integration can be used to calculate areas and volumes in various real-life scenarios.
