Can You Define "Term" and "Expression" in Math?
In summary, terms are expressions that are added or subtracted, and they can be made up of factors that are multiplied together. Expressions, on the other hand, can involve any arithmetic operation and can also include exponents, roots, and functions. The term "term" is most commonly used in the context of polynomials, but is not strictly defined.
bballwaterboy
85
I have heard different things and want to get a "professional" opinion on this.
It seems like the words "term" and "expression" are technical terms with specific definitions in math and I want to know what they technically refer to (not just the personal slang or informal definitions someone might assign to them, but rather their formal mathematical definitions).
Thanks!
(p.s. I know this is simple algebra stuff, but that's my level right now.)
Mathematics news on Phys.org
Terms are expressions that are added or subtracted, such as 3xy + 2z or b2 - 4ac. In the first expression, 3xy is one term and 2z is another term. In the second expression, the terms are b2 and -4ac.
In the 3xy term, 3, x, and y are factors, which are expressions that are multiplied to make up the term.
Expressions are more loosely defined. They could be made up from any of the arithmetic operations - addition, subtraction, multiplication, or division, but can also be made up by raising an expression to some power (such as (a + b)3/2), roots (such as ##\sqrt[3]{a - 1}##), or involve trig or exponential or log functions, just to name a few.
Hi, Mark44:
Thanks for the answer. So to clarify, terms are only expressions that are ADDED or SUBTRACTED - nothing else?
What about division of expressions, such as 3x/y or perhaps a simple exponent like 4^2? These don't have addition or subtraction of the expressions. So, you're saying these wouldn't be terms, correct?
TVM!
bballwaterboy said:
Hi, Mark44:
Correct.
If you had 3x/y + 4x2, the 3x/y and 4x2 parts might be considered terms, although "term" is probably more often used in the context of polynomials, where each term is a constant or a constant times integer powers of one or more variables, such as 3, 2x, 5xy3, and so on. As far as I know, "term" isn't rigidly defined.
Related to Can You Define "Term" and "Expression" in Math?
1. What is the difference between a term and an expression in math?
A term is a single numerical value, variable, or a combination of both that is separated by addition or subtraction. An expression is made up of one or more terms connected by mathematical operations.
2. Can you give an example of a term and an expression?
An example of a term would be 3x or 7. An expression could be 3x + 5 or 2x^2 + 4x - 1.
3. How do you simplify a math expression?
To simplify a math expression, you need to combine like terms, perform any necessary operations (such as addition, subtraction, multiplication, and division), and simplify any exponents or parentheses present in the expression.
4. What is the purpose of using terms and expressions in math?
Terms and expressions are used in math to represent and solve mathematical problems and equations. They allow us to break down complex equations into smaller, more manageable parts, making them easier to solve.
5. Are there any rules for combining terms in an expression?
Yes, there are a few rules for combining terms in an expression. First, terms with the same variable and exponent can be combined by adding their coefficients. Second, terms with different variables cannot be combined, unless they are constants. Finally, like terms can also be combined by subtracting their coefficients if they are separated by a minus sign.
  • General Math
  • General Math
