MHB Can You Determine the Sum of All Natural Numbers Less Than Their Combined Roots?
  • Thread starter Thread starter Albert1
    Summation
Albert1
$ n\in N$
$n<\sqrt n + \sqrt[3]{n} + \sqrt[4]{n}$
find :$ \sum n $
Mathematics news on Phys.org
My solution:
I would write the given inequality as:
$$n-n^{\frac{1}{2}}-n^{\frac{1}{3}}-n^{\frac{1}{4}}<0$$
Divide through by $$n^{\frac{1}{4}}>0$$ to obtain:
$$n^{\frac{3}{4}}-n^{\frac{1}{4}}-n^{\frac{1}{12}}-1<0$$
Let $$u=n^{\frac{1}{12}}$$ and we have:
$$u^9-u^3-u-1<0$$
Defining:
$$f(u)=u^9-u^3-u-1$$
we see that:
$$f(1)<0$$ and $$f(2)>0$$
and:
$$f'(u)=9u^8-3u^2-1$$
we see also that:
$$f'(x)>0$$ for $$1\le x$$
So we may apply Newton's method to find the real root of $f$ on $(1,2)$.
$$u_{n+1}=u_n-\frac{f\left(u_n \right)}{f'\left(u_n \right)}$$
Using the definition of $f$, we have:
$$u_{n+1}=u_n-\frac{u_n^9-u_n^3-u_n-1}{9u_n^8-3u_n^2-1}=\frac{8u_n^9-2u_n^3+1}{9u_n^8-3u_n^2-1}$$
Letting $u_0=1$, we then recursively obtain:
$$u_1=1.4$$
$$u_2\approx1.27679115672466$$
$$u_3\approx1.19600432443480$$
$$u_4\approx1.16202903329198$$
$$u_5\approx1.15671666316563$$
$$u_6\approx1.15660010278918$$
$$u_7\approx1.15660004786155$$
$$u_8\approx1.15660004786153$$
$$u_9\approx1.15660004786153$$
Hence we know $$u\approx1.15660004786153$$ is the only real root of $f$ on $[1,\infty)$ and so:
$$n=u^{12}\approx5.73057856869580$$
Hence:
$$n\in\{1,2,3,4,5\}$$
And so:
$$\sum n=15$$
Albert said:
$ n\in N$
find :$ \sum n $
$n<\sqrt n + \sqrt[3]{n} + \sqrt[4]{n}=k$
$3\sqrt[3]{n} <k<3 \sqrt[2]{n}$
if $n<3\sqrt[2]{n}$,then $n<9---(1)$
if $n<3\sqrt[3]{n}$,then $n<6---(2)$
for :$7=3+2+2=\sqrt 9+\sqrt [3]{8} +\sqrt[4]{16}>\sqrt 7+\sqrt[3]{7}+\sqrt[4]{7}$
$\therefore \sum n =1+2+3+4+5=15$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
