tahayassen
- 270
- 1
Such as f(x)=(x^2+1)(x+1)?
Diffy said:I don't understand the question? Why would you need calculus to draw something? Can't you just plug in x's and make a table of points?
Can you elaborate on what you mean?
Clearly the only real root is at x = -1. For values of x close to -1, but less than -1, x + 1 < 0, and x2 + 1 ≥ 1 (since x2 ≥ 0 for any real x). This means that the function values are going to be negative for x to the left of -1. Since the only root is at x = -1, all function values are negative when x < -1.tahayassen said:Such as f(x)=(x^2+1)(x+1)?
Mark44 said:Clearly the only real root is at x = -1. For values of x close to -1, but less than -1, x + 1 < 0, and x2 + 1 ≥ 1 (since x2 ≥ 0 for any real x). This means that the function values are going to be negative for x to the left of -1. Since the only root is at x = -1, all function values are negative when x < -1.
You can continue this kind of analysis for x > -1.
It's enough information to get a rough graph of this function.tahayassen said:But that isn't enough information to graph the function.
You didn't mention anything about concavity in your first post. In fact, this is the first you've mentioned concavity in this thread.tahayassen said:My original question was referring to the change of concavity of f(x) at x = 0.
Yes. If there is 1 real root, there are 2 complex roots.tahayassen said:Okay, I'm on a desktop now, so hopefully, I can be clear. Cubic functions can be roughly sketched by using the real roots. Note: my definition of a rough sketch means you get the concavities right and the end behaviour of the function right.
If you have a real root with multiplicity 1, then the function clearly passes through the x-axis. Multiplicity 2 means that it does something similar to x^2 does at x=0. Multiplicity 3 means the function does a little wiggle.
Cubic functions either have 1 or 3 real roots (is this correct?).
For this case where there are three roots, there are a couple possibilities:tahayassen said:If they have 3 real roots, then you can roughly sketch it by using the multiplicity thing I was talking about earlier.
No, complex roots aren't repeated. They always come in conjugate pairs. For example, if z = a + bi is a root of a cubic polynomial, the other complex root will be z = a - bi.tahayassen said:If it has 1 real root, then you run into a small issue. You get a real root with multiplicity 1 at a certain x value, so you know the function goes right through the x-axis at that point. However, you also can get a complex root with multiplicity 2 (e.g. f(x) in the OP).
If you are graphing a cubic polynomial on the real plane, all you need to be concerned with are the real roots. There is no "wiggle" due to complex roots.tahayassen said:Because it is complex, it still does the wiggle, but the wiggle isn't on the x-axis.
tahayassen said:I was wondering if there's a way to find where the coordinates (x, y) of the wiggle is in f(x).
Mark44 said:There is no "wiggle" due to complex roots.
A cubic function is a polynomial function of the form f(x) = ax^3 + bx^2 + cx + d, where a, b, c, and d are constants and x is the independent variable. This type of function has a degree of 3, meaning the highest power of the independent variable is 3.
A cubic function can have one, two, or three real roots. To determine if it has one real root, you can use the discriminant (b^2 - 4ac) to see if it is equal to zero. If it is, then the function has one real root. Additionally, you can graph the function and see if it crosses the x-axis at only one point.
A real root is a value of the independent variable (x) that makes the function equal to zero. In other words, it is the x-value where the function crosses the x-axis. A complex root is a root that involves imaginary numbers (i.e. the square root of a negative number). In the case of a cubic function, a real root is a value that can be graphed on the x-axis, while a complex root cannot.
Yes, it is possible to draw a cubic function with one real root without using calculus. One method is to use the rational root theorem to find potential rational roots, and then use synthetic division to test those roots and determine the remaining factors. This will give you the x-intercepts of the function, and you can then sketch the curve based on those points.
Drawing a function without using calculus can be helpful for understanding the behavior and characteristics of the function. It can also be useful in situations where calculus is not necessary or not accessible, such as in introductory math or science courses. Additionally, practicing this skill can improve problem-solving abilities and strengthen understanding of algebraic concepts.
