Can you evaluate this integral using series and historical methods?
  • MHB
  • Thread starter vilhelm
  • Tags
    Integrate
In summary, the integral $\displaystyle\int_0^\infty \frac{dx}{1+x^3}$ can be solved using contour integration or the Beta function. It can also be approached by considering a series expansion of the denominator and splitting the integral into two parts. This method has historical significance in the infamous calculus battle between Leibniz and Newton.
vilhelm
37
Would be very grateful if someone helped me on this.
oooppp2 said:
Would be very greatful if someone helped me on this.
$x^3+1$ has the root $x=-1$.
Therefore we can factorize it:
$$x^3 + 1 = (x+1)(x^2-x+1)$$
Next step is partial fractions...
It can be solved by contour integration or by Beta function .
\(\displaystyle \int_0^\infty \frac{dx}{1+x^3} =\frac{1}{3} \int_0^\infty \frac{x^{\frac{1}{3}-1}}{1+x } dx =\frac{1}{3} \Gamma \left( \frac{1}{3}\right) \Gamma \left(1- \frac{1}{3}\right) = \frac{\pi }{3 \sin \left (\frac{\pi }{3} \right) } = \frac{2\pi }{3 \sqrt{3}}\)
First calculus course, so I have not learned that.
- - - Updated - - -
Thanks, I'll try it and update with my progress.
I hope I didn't create confusion for you. It is important to keep in mind that this problem can be solved by complex analysis approaches , if you are going to take this course in the future .
oooppp2 said:
Looks like you know how to do it.
Good. ;)
However, in your last 2 lines you write:
\begin{array}{lcl}
1 &=& \frac 1 3 + 2B + \frac 4 3 \\
B &=& -\frac 4 3
\end{array}
But if I substitute that, I get:
\begin{array}{lcl}
1 &=& \frac 1 3 + 2 \cdot (- \frac 4 3) + \frac 4 3 \\
1 &=& -\frac 3 3
\end{array}
But... that does not seem right!For the next steps, you might work toward the following integrals:
\begin{array}{lcl}
\int \frac {du}{1+u^2} &=& \arctan u + C \\
\int \frac {u du}{1+u^2} &=& \frac 1 2 \ln(1+u^2) + C
\end{array}
Good. ;)
\begin{array}{lcl}
B &=& -\frac 4 3
\end{array}
\begin{array}{lcl}
1 &=& -\frac 3 3
\end{array}
\begin{array}{lcl}
\end{array}
Here is my attempt. I'm still a bit stuck...
https://www.dropbox.com/s/9gub6zq02b5235b/Screenshot 2013-10-26 21.13.45.png
oooppp2 said:
This link looks to me like a screen shot taken while you were composing a post.
Let's look at the partial fraction decomposition:
\(\displaystyle \frac{1}{x^3+1}=\frac{1}{(x+1)\left(x^2-x+1 \right)}=\frac{A}{x+1}+\frac{Bx+C}{x^2-x+1}\)
Multiplying through by \(\displaystyle (x+1)\left(x^2-x+1 \right)\) we obtain:
\(\displaystyle 1=A\left(x^2-x+1 \right)+(Bx+C)(x+1)\)
\(\displaystyle 1=Ax^2-Ax+A+Bx^2+Bx+Cx+C\)
\(\displaystyle 0x^2+0x+1=(A+B)x^2+(-A+B+C)x+(A+C)\)
Comparison of coefficients results in the linear system:
\(\displaystyle A+B=0\)
\(\displaystyle -A+B+C=0\)
\(\displaystyle A+C=1\)
What do you find when you solve this system?
\begin{array}{lcl}
\end{array}
But for the arctan(u) and ln(1+u^2) should I take the limit as n goes to infty? How is that done? Thanks.
As an aside, in light of Zaid's answer to this Q, you can use his reside / Beta Integral derivation to consider certain series evaluations...
Let
\(\displaystyle I_n=\int_0^{\infty}\frac{dx}{(1+x^n)}\)Specifically, it might be interesting to expand the \(\displaystyle (1+x^n)\) term in the denominator via
\(\displaystyle (1+x^n)=\sum_{k=0}^{\infty}(-1)^kx^{kn}\)
However, this series has radius of convergence \(\displaystyle r=1\), so first we'd need to split the integral into:
\(\displaystyle I_n=\int_0^1 \frac{dx}{(1+x^n)}+\int_1^{\infty}\frac{dx}{(1+x^n)}\)Now apply the substitution \(\displaystyle x=1/y\), \(\displaystyle dx=-dy/y^2\) on the second integral to get:\(\displaystyle I_n=\int_0^1\frac{dx}{(1+x^n)}-\int_1^0\frac{dy}{y^2(1+(1/y)^n)}=\)\(\displaystyle \int_0^1 \Bigg\{ \frac{1}{1+x^n}+\frac{x^{n-2}}{(1+x^n)} \Bigg\} \,dx= \int_0^1\frac{1}{1+x^n}(1+x^{n-2})\,dx=\)\(\displaystyle \sum_{k=0}^{\infty} (-1)^k\int_0^1x^{kn}(1+x^{n-2})\,dx\)
From a historical point of view, this type of integral is particularly interesting with regards to the infamous calculus battle between Leibniz and Newton... Leibniz used the case n=2 to prove what is now famously, and indeed mistakenly (!), called Leibniz's Series:
\(\displaystyle \int_0^1\frac{dx}{1+x^2}=1-\frac{1}{3}+\frac{1}{5}-\frac{1}{7} + \cdots = \frac{\pi}{4}
[This series was known to Madhava in the Fourteenth Centurty :eek: )To which Newton replied by evaluating the case for n=4 in two different ways, to show that:
\(\displaystyle \int_0^1\frac{1+x^2}{1+x^4}\,dx=1+\frac{1}{3}-\frac{1}{5}-\frac{1}{7}+\frac{1}{9}+\frac{1}{11}- \cdots = \frac{\pi}{2 \sqrt{2}}\)
Ermmm... Seem to have wandered a tad off-topic here. Whoops! (Heidy)Back on-topic: If you consider Zaid's answer above, and the series form given here, then you have two different evaluations of each integral - much like Sir Isaac Newton - for the parameter n. Standing on the shoulders of giants indeed... (Rock)
FAQ: Can you evaluate this integral using series and historical methods?
What is the general formula for integrating dx/(1+x^3)?
The general formula for integrating dx/(1+x^3) is (1/3)ln|1+x^3| + C, where C is the constant of integration.
Can I use u-substitution to solve this integral?
Yes, you can use u-substitution by letting u = 1 + x^3 and du = 3x^2 dx. This will result in the integral becoming (1/3)∫du/u, which can be easily integrated using the natural logarithm function.
Is there a way to solve this integral without using u-substitution?
Yes, you can also use partial fractions to solve this integral. By decomposing dx/(1+x^3) into (A+Bx)/(1+x^3), where A and B are constants, you can then solve for A and B and integrate each term separately.
Can I use trigonometric substitution to solve this integral?
Yes, you can use trigonometric substitution by letting x = tanθ and using the identity 1 + tan^2θ = sec^2θ. This will result in the integral becoming (1/3)∫secθdθ, which can be easily solved using the natural logarithm function.
Are there any real-world applications of this integral?
Yes, this integral can be used in calculus and physics to calculate the area under a curve. It can also be used in engineering and economics to solve problems involving optimization and rates of change.
