Can you explain how space-time gravity works? I don't think it does.
In summary: Ugh. You get the idea.In summary, according to these two analogies, Einstein predicted that there was no force of gravity, that it could be subsituted with accelaration, and that gravity is made by bent space time. However, his analogies do not work and he is wrong.
  • #36
Originally posted by meister
Is this GR saying there is no gravitational force or is this classical physics?
What do you mean by that? What is the 'this' to which you are referring?
  • #37
On my way here, I stopped by Cyto's thread over in "Theory Development". These two topics are very closely related, so each of you should probably watch the other's thread for possible insights into your own.
Regarding gravity as "acceleration"; perhaps the best way toward clear understanding is to take what you now know about the curvature being in the fourth dimension, and apply it to a principal which I'm sure you have heard of numerous times, that the fourth dimension is time. From this perspective, it can be said that your passage through time is what's being curved by gravity.
So, as you progress toward the future, the Earth's mass curves your path. Applying relativity to look at the situation from your perspective, your path appears straight and it is the Earth that is curving. The Earth's (from your perspective) curved trajectory across time causes it to maintain contact with your feet, continuously pushing you off of your path. This ongoing deflection from the path you would take is the acceleration that you feel as gravity.
  • #38
Graviataional fields curve all dimensions of space-time, spatial and temporal.
  • #39
I was referring to this whole post:
Originally posted by Chi Meson
You said:
"since you were inside of the elvator, when it accelarated the force pushed you against the floor to simulate gravity."
And there is your error in understanding. THere is no force at all pushing you against the floor. IF your book says that there is, throw it away.
THe force on you, is the floor pushing "up" on you.
Ohhhh, is he just talking about space where the force of the Earth's gravity can be neglected for the most part?
  • #40
Yes, the events in the elevator take place in some remote part of space where no noticable gravitational field exists. In such a location, you should float around in the elevator. But, if the elevator begins top move, you are held to the floor. As long as it continues to accelerate, you remain on the floor (in fact, the wall of the elevator you call "the floor" would be entirely defined by which way it accelerates). If there are no windows, no way of getting an outside refference with which to compare yourself, the difference between accelerating through empty space and sitting still on the ground on Earth is... NO difference at all!
  • #41
so the vector for the acceleration of gravity at the Earth's surface would be- straight up.
  • #42
First a definition.
Inertial Force - The force on a given object due which results soley on observing the motion from a non-inertial frame of referance. Any force which is proportional to mass is regarded as an inertial force.
Originally posted by Cyberice
Anyway, Einstein supposedly proved that there was no force of gravity, that it could be subsituted with accelaration, and that gravity is made by bent space time. I have quite a few (semmingly) errors in which I may have just misinterpreted but desire to point out.
That's not quite correct. Einstein himself never said gravity was not a force. What he showed was that gravity and inertial forces are identical in nature. In Newtonian mechanics one might be tempted to think that inertial forces are not "real" forces. However Einstein saw things differently. To him, and thus his theory, inertial forces are "real."
The first is the gravity/accelaration annalogy of Einstien in a rotating elevator in space. The analogy is fine and makes sense. It states that if you were to be in a constantly accelarated (rotated) elevator in space it would pull you to the floor of the elevator and would simulate gravity, and if there were no windows you could not tell the difference if you were in an elevator on the earth.
Einstein's equivalence principle is stated as follows
A uniform gravitational field is equivalent to a uniformly accelerating frame of referance.
The rotating frame is not a uniformly accelerating frame of referance. You *can* tell you're in a rotating frame. Suppose you're standing on the surface of the Earth. If you stand up straight and drop a stone then the stone will fall straight down and land by your feet. If you're inside the rotating frame and are standing straight up and drop a stone thent the stone will *not* land by your feet. It will be deflected. This is the coriolis force.
And even if you're standing on the surface of the Earth you can, in principle, tell if you're in a gravitational field or an accelerating frame of referance in the absence of gravity.
The gravitational field of the Earth has tidal forces. No such forces are present in the absence of gravity.
And gravity is not a curvature in spacetime - Gravitational tidal forces are. I.e. gravitational tidal forces and spacetime curvature are one in the same thing.
But in general you don't have to have tidal forces to have a gravitational field. In fact the equivalence principle is based on this fact - that a uniform gravitational field has no tidal force an therefore there is no spacetime curvature. And there's no reason why there can't be uniform gravitational fields someplace.
Consider a spherical body which has a uniform mass density. If you hollow out a spherical cavity - the center of which is *off set* from the center of the body, then inside the cavity there will be a uniform gravitational field and thus no spacetime curvature.
Now suppose you're standing up in a uniform gravitational field. Then you are *at rest* in the field. That means that the total force acting on you is zero. The forces acting on you are the force of he floor pushing you up and the force of gravity pulling you down.
Pete
Pete
  • Astronomy and Astrophysics
