Can you find $f^{(n)}(1)$ with the given conditions?
  • MHB
  • Thread starter lfdahl
  • Tags
    Derivative
In summary, the nth derivative refers to the derivative of a function taken n times and is important in understanding the behavior of a function, making predictions, and solving complex problems. It can be found using various rules and techniques such as the power rule, product rule, and binomial theorem. The first derivative represents the slope of a function while the nth derivative represents the rate of change of the slope. The nth derivative can be negative depending on the behavior of the function and its derivatives at a given point.
lfdahl
MHB
749
Let $f(x)$ be a function satisfying
\[xf(x)=\ln x \ \ \ \ \ \ \ \ \text{for} \ \ x>0\]
Show that $f^{(n)}(1)=(-1)^{n+1}n!\left(1+\frac{1}{2}+\cdots+\frac{1}{n}\right)$ where $f^{(n)}(x)$ denotes the $n$-th derivative evaluated at $x$.
Mathematics news on Phys.org
My solution:
We have:
\(\displaystyle f(x)=\frac{\ln(x)}{x}\)
Now, let's look at a few base cases to see if a pattern emerges:
\(\displaystyle f^{(1)}(x)=\frac{1-\ln(x)}{x^2}\)
\(\displaystyle f^{(2)}(x)=\frac{2\ln(x)-3}{x^3}\)
\(\displaystyle f^{(3)}(x)=\frac{11-6\ln(x)}{x^4}\)
\(\displaystyle f^{(4)}(x)=\frac{24\ln(x)-50}{x^5}\)
I'm ready to posit the inductive statement $P_n$:
\(\displaystyle f^{(n)}(x)=\frac{(-1)^nn!\left(\ln(x)-H_n\right)}{x^{n+1}}\)
Note: $H_n$ is the $n$th harmonic number, defined as:
\(\displaystyle H_n\equiv\sum_{k=1}^{n}\left(\frac{1}{k}\right)\)
We already know the base case is true, so as our inductive step, let's differentiate both sides w.r.t $x$:
\(\displaystyle f^{(n+1)}(x)=\frac{x^{n+1}\left((-1)^nn!\frac{1}{x}\right)-(-1)^nn!\left(\ln(x)-H_n\right)(n+1)x^n}{\left(x^{n+1}\right)^2}=\frac{(-1)^nn!\left(1-(n+1)(\ln(x)-H_n\right)}{x^{n+2}}=\frac{(-1)^{n+1}(n+1)!\left(\ln(x)-H_{n+1}\right)}{x^{(n+1)+1}}\)
We have derived $P_{n+1}$ from $P_n$, thereby completing the proof by induction. Hence:
\(\displaystyle f^{(n)}(1)=\frac{(-1)^nn!\left(\ln(1)-H_n\right)}{1^{n+1}}=(-1)^{n+1}n!H_n\)
Shown as desired. :D
MarkFL said:
My solution:
We have:
What a nice solution, MarkFL, thankyou for your participation! :cool:
FAQ: Can you find $f^{(n)}(1)$ with the given conditions?
What is the nth derivative?
The nth derivative refers to the derivative of a function taken n times. It represents the rate of change of the rate of change of a function.
Why is finding the nth derivative important?
Finding the nth derivative allows us to understand the behavior of a function at a specific point and to make predictions about its future values. It is also useful in solving complex mathematical problems and in various fields such as physics and engineering.
How do you find the nth derivative?
To find the nth derivative, you can use the power rule, product rule, quotient rule, or chain rule depending on the given function. You can also use the binomial theorem or Taylor series to find the derivative of more complex functions.
What is the difference between the first and nth derivative?
The first derivative represents the slope of a function at a given point, while the nth derivative represents the rate of change of the slope at that point. In other words, the first derivative gives information about the shape of the function, while the nth derivative gives information about the shape of the first derivative.
Can the nth derivative be negative?
Yes, the nth derivative can be negative if the function is decreasing at that point. The sign of the nth derivative depends on the behavior of the function and its derivatives at that point.
