Can you help me determine the convergence of these series?
In summary: Thank you!In summary, the conversation is about determining whether three different series converge, converge conditionally, or converge absolutely. The three series are represented by equations a), b), and c), with each having a specific range for the variable k. The person asking for help has attempted to use the integral test and the alternating series test, but is unable to solve the problem and is seeking assistance. However, it is a violation of PF rules to offer help without the OP showing their work.
ellaingeborg
Member warned that some effort must be shown
Determine whether the following series converge, converge conditionally, or converge absolutely.
a) Σ(-1)^k×k^3×(5+k)^-2k (where k goes from 1 to infinity)
b) ∑sin(2π + kπ)/√k × ln(k) (where k goes from 2 to infinity)
c) ∑k×sin(1+k^3)/(k + ln(k)) (where k goes from 1 to infinity)
I tried using the integral test and the alternating series test, but couldn't figure it out. Any help is appreciated, thank you.
It's difficult to help you if you don't show us what you have tried. Let's start with part a). Show us how you would apply the alternating series test to it.
More to the point: it is a violation of PF rules for us to offer help if the OP has not shown the work done.
@ellaingeborg, please pick one of the three problems and show us what you have tried.
All others, please refrain from posting until we hear back from the OP.
Likes scottdave
FAQ: Can you help me determine the convergence of these series?
What is the definition of convergence of a series?
The convergence of a series refers to the behavior of a sequence of numbers when they are added together. It is said to converge if the sum of the terms approaches a finite limit as more terms are added.
How is the convergence of a series determined?
The convergence of a series is determined by analyzing the behavior of the terms in the series. If the terms tend to decrease or approach a finite limit, then the series is said to converge. If the terms do not have a clear pattern or tend to increase without bound, then the series is said to diverge.
What is the difference between absolute and conditional convergence?
Absolute convergence refers to a series where the sum of the absolute values of the terms converges. Conditional convergence refers to a series where the sum of the terms converges, but the sum of the absolute values of the terms does not converge.
Can a series converge to a value other than the sum of its terms?
Yes, a series can converge to a value other than the sum of its terms. This can happen if the series has a special form, such as an alternating series, or if the series is multiplied by a convergent factor.
What are the common tests for convergence of a series?
Some common tests for convergence of a series include the comparison test, the ratio test, and the root test. These tests help determine the behavior of the terms in a series and whether it converges or diverges.
