Can you multiply the double angle forumla?
  • Thread starter Thread starter musiclover55
    Angle
The discussion clarifies that sin(4x) cannot be directly expressed as 4sin(x)cos(x) using the double angle formula. Instead, the correct approach involves recognizing sin(4x) as sin(2(2x)), allowing the application of the double angle formula, which states sin(2A) = 2sin(A)cos(A). By substituting A with 2x, the expression can be rewritten correctly. Careful adherence to the formula patterns is essential for accurate transformations. Understanding these nuances is crucial for solving trigonometric equations effectively.
musiclover55
I have sin4x, can I use the double angle forumla and make it 4sinxcosx?
sin4x----> 4sinxcosx
...try graphing both and see if they're the same.
In a word, no.
The double-angle formula says that sin(2A) = 2*sin(A)cos(A).
When you use formulas, you need to be very careful to follow the pattern being used.
If you write sin(4x) as sin(2(2x)), you can use the double-angle formula, replacing A in the above by 2x.
  • · Replies 19 ·
14K
  • · Replies 42 ·
  • · Replies 19 ·
