Can You Propel Yourself Back on a Chair?
  • B
  • Thread starter Skeptic Tom
In summary, the conversation discusses the possibility of self-propelling oneself while sitting on a chair and using one's legs as the only force. The participants share their thoughts and experiences on the subject, mentioning the importance of friction and the use of wheels for successful propulsion. They also mention the connection to physics and how it can be achieved with practice. However, there is also a mention of the difficulty in achieving this on certain surfaces and without contact with the floor.
Skeptic Tom
TL;DR Summary
Is it possible to sit on a chair and self propel oneself back while still sitting on it?
It may seem a bit silly this but I was told by a friend that it is possible to sit on a chair, wooden or plastic and propel oneself back by using ones legs, say a distance of one meter, while still sitting on the chair, in one sudden quick movement. I tried it but found it impossible. The plastic chair did not move one centimetre, the legs just twisted and almost broke. Isn't that a bit like saying to someone, 'can you lift a basket up while standing inside it'? I asked the person to try it themselves but they said they were not fit enough to do it, adding that a fit agile young person could do it. Perhaps if the chair had wheels on it, then yes, one could propel oneself back, but not an ordinary garden or dining room chair. Thoughts?
I'm not sure what you mean by "propel oneself back by using ones legs". Certainly, you can push yourself back by pressing your feet against the floor!
If you mean that you sit in the chair and, without making contact with the floor or other "external" structure but just "waving" you legs and feet, the "maybe"! But in order to move at all there would have to be some kind of friction so that you legs and feet are, in fact, making contact with something. If there is no friction, or only neglible friction then, no, "conservation of momentum" prevents any "external" motion without "external" force.
Likes Skeptic Tom
Skeptic Tom said:
Summary:: Is it possible to sit on a chair and self propel oneself back while still sitting on it?
you are standing inside your shoes. Can you jump?
Likes Skeptic Tom, etotheipi and Dale
Mexican Jumping Bean
Thanks for your reply HallsofIvy…... I mean while the person is sitting on the chair with their legs and feet tucked under the chair and with one sudden movement, using their feet against the surface (wooden floor, tile floor or stone floor) to push the chair back about one meter while still remaining seated.With just one initial force using the feet against one of these surfaces to propel oneself back. Only one big push is permitted. So, yes, there would be contact with the floor. I tried it on the three surfaces listed but no movement. I am sure it would be possible if one was sitting on a chair sitting on a very smooth surface, such as ice and using ones legs to push against, say a wall. That would work but I can't see how it would work on the surfaces listed. I was not able to push myself back as described.
This is the key. There needs to be some friction, but not too much.
Likes Skeptic Tom
Skeptic Tom said:
I am sure it would be possible if one was sitting on a chair sitting on a very smooth surface, ...
So you see that there is nothing in physics that prevents this in principle?
Skeptic Tom said:
... but I can't see how it would work on the surfaces listed. I was not able to push myself back as described.
Practice, practice, practice...
  • Haha
Likes berkeman
You need to get your weight over your feet when you push and then back onto (the less "frictiony") chair for the slide.
This is sort of the way cross country skis provide propulsion.
Likes Skeptic Tom and Keith_McClary
Exactly. @Skeptic Tom, there can be a situation where jerking your legs out suddenly will create enough force to overcome the friction of the chair/floor and then drawing them back in slowly will not create enough force to overcome that friction. You could go all the way across the room with multiple jerks.
If you watch The Blues Brothers, you can see Jake and Elwood do this when visiting The Penguin.
Likes hutchphd, russ_watters, anorlunda and 1 other person
It's easy to do standing on a small carpet or piece of fabric.
People do it all the time sitting on office chairs with casters. This contemporaneous thread deals with the question of why it is easier to roll than to slide. Your experiments illustrate what is said in that thread. A word of caution: it is voluminous and it's up to you to separate the wheat from the chaff.
It's a matter of the friction on the soles of ones feet and the friction on the feet (or casters) on the chair. And that, of course, also depends on the floor surface.
No, you can't USE your feet on the floor. That was the point of the question although it wasn't stated very clearly.
OOPS ... I see that he clarified in post #5 that is IS talking about using your feet on the floor, so my post #9, while correct, did not address his question.
Related to Can You Propel Yourself Back on a Chair?
1. How does the physics behind propelling oneself back on a chair work?
The physics behind propelling oneself back on a chair involves the conservation of angular momentum. When you push off with your feet, you create a torque that rotates the chair and yourself in the opposite direction. This increases the angular velocity, allowing you to propel yourself back.
2. Is it safe to propel yourself back on a chair?
Propelling yourself back on a chair can be dangerous if not done properly. It is important to have a stable and sturdy chair, and to push off with enough force to create the necessary torque. It is also important to have good balance and control to prevent falling or tipping over.
3. Can anyone propel themselves back on a chair?
Most people are able to propel themselves back on a chair, as long as they have the necessary strength and coordination. However, it may be more difficult for individuals with certain physical limitations or disabilities.
4. Are there any benefits to propelling oneself back on a chair?
Propelling oneself back on a chair can be a fun and entertaining activity, but it also has some physical benefits. It can help improve balance, coordination, and leg strength.
5. Are there any risks associated with propelling oneself back on a chair?
As with any physical activity, there are some risks associated with propelling oneself back on a chair. These include the potential for falling or tipping over, as well as strain on the muscles and joints if done excessively or improperly.
  • Other Physics Topics
  • General Engineering
  • General Discussion
  • Biology and Medical
21K
