Can You Prove $ab\le 1$ Given $(x+a)(x+b)=9$?
  • MHB
  • Thread starter anemone
In summary, we can prove $ab \le 1$ for $(x+a)(x+b) = 9$ by expanding the equation, using the quadratic formula and the discriminant, and setting the discriminant to be greater than or equal to 0. Other properties of quadratic equations and inequalities, such as the AM-GM inequality, can also be used to prove this statement. This proof helps us understand the solutions of the equation and can be applied to other mathematical problems.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
The equation $(x+a) (x+b) = 9$ has a root $a+b$.
Prove that $ab\le 1$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. Olinguito
2. castor28
3. kaliprasad
Solution from Olinguito:
We have
$$(a+b+a)(a+b+b)=9$$
$\implies\ 2b^2+5ba+2a^2-9\ =\ 0$.
Treating this as a quadratic equation in $b$,
$$b\ =\ \frac{-5a\pm\sqrt{(5a)^2-4(2)(2a^2-9)}}4\ =\ \frac{-5a\pm3\sqrt{a^2+8}}4$$
$\implies\ ab\ =\ \dfrac{-5a^2\pm3a\sqrt{a^2+8}}4.$
We want to show that this is less than or equal to $1$. Assume to the contrary that it is greater than $1$:
$$\dfrac{-5a^2\pm3a\sqrt{a^2+8}}4\ >\ 1$$
$\implies\ \pm3a\sqrt{a^2+8}\ >\ 4+5a^2.$
The RHS is greater than $0$ so we can square the inequality:
$$9a^2(a^2+8)\ >\ 25a^4+40a^2+16$$
$\implies\ 0\ >\ 16a^4-32a^2+16\ =\ 16(a^2-2)^2.$
We have a contradiction; therefore the assumption that $ab>1$ is false. Hence $\boxed{ab\leqslant1}$.
Alternative solution from castor28:
The equation can be written as $x^2+(a+b)x+ab=9$. As $x=a+b$ satisfies the equation, we have:
2(a+b)^2+ab=9
Using the identity $(a+b)^2 = (a-b)^2+4ab$, we get:
\begin{align*}
2(a-b)^2 + 9ab&=9\\
9ab&\le9\\
ab&\le1
\end{align*}
FAQ: Can You Prove $ab\le 1$ Given $(x+a)(x+b)=9$?
What is the significance of proving $ab\le 1$ for $(x+a)(x+b)=9$?
The significance of this proof is that it provides insight into the possible values of $x$ and the coefficients $a$ and $b$ in the equation $(x+a)(x+b)=9$. It also helps in understanding the behavior of the equation and its solutions.
How can we prove $ab\le 1$ for $(x+a)(x+b)=9$?
This can be proven by using the quadratic formula and manipulating the equation to show that the product of $a$ and $b$ is less than or equal to 1. Alternatively, we can also use algebraic manipulation and factoring to prove this inequality.
Are there any specific conditions or restrictions for this proof to hold true?
Yes, in order for $ab\le 1$ to be true for $(x+a)(x+b)=9$, the values of $a$ and $b$ must be real numbers and $x$ must also be a real number such that the equation has real solutions.
How does this proof relate to other mathematical concepts?
This proof is closely related to the concept of quadratic equations and their solutions. It also involves the use of algebraic manipulation and the quadratic formula. Additionally, it can be used to understand the behavior of quadratic functions and their graphs.
Can this proof be extended to other equations or inequalities?
Yes, this proof can be extended to other equations or inequalities involving quadratic functions. It can also be applied to other mathematical concepts such as systems of equations and inequalities, and optimization problems.
