Can You Prove $\sin(2^{25})^\circ = -\cos(2^\circ)$?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, the conversation discussed the equation sin(2^25)^o = -cos 2^o and its significance in trigonometry. The notation "2^25" was defined as representing 2 raised to the 25th power, and the "o" symbol in the equation was explained to represent degrees. It was mentioned that the double angle identity for sine will be used to prove the equation, and this would demonstrate the relationship between sine and cosine for angles that are double each other. Overall, proving this equation reinforces a fundamental concept in trigonometry.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Prove that $\sin(2^{25})^{\circ}=-\cos 2^{\circ}$
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the kaliprasad for his correct solution, which you can find below::)
Let us first find $2^{25}\,\pmod {360}$
we have $360 = 2^3 * 45$
$2^{25} \equiv 0 \pmod {2^3}\cdots(1)$
to evaluate $2^{25}\, \pmod \, {45} $ we proceed as below
$\phi(45) = \phi(5 * 3^2) = 45 * ( 1- \frac{1}{5})( 1- \frac{1}{3})$
as 2 and 45 are coprimes So as per Eluer's theorem
$2^{\phi(45)} \equiv 1 \pmod{45}$
or $2^{24} \equiv 1 \pmod{45}$
hence $2^{25} \equiv 2 \pmod{45}\cdots(2)$
using (1) and (2) we should able to find $2^{25}\,\pmod {360}$
we have from (2) the value should be $45k+2$ ( k from 0 to 7) and from (1) $45k+2 \equiv 0 \pmod 8$
k cannot be odd as 45k+2 need to be even
k cannot be multiple of 4 (that is neither 0 nor 4) then 45k+2 shall not be divisible by 8
checking for k = 2 and 6 we get k = 6
so $2^{25} \equiv 272 \pmod{360}$
hence
$\sin(2^{25})^\circ = \sin(272^\circ) = \sin(360-272)^\circ = \sin\,- 88^\circ = - \sin\, 88^\circ = - \cos \,2^\circ$
FAQ: Can You Prove $\sin(2^{25})^\circ = -\cos(2^\circ)$?
What is the equation that needs to be proven?
The equation that needs to be proven is sin(2^25)^o = -cos 2^o.
What does the notation "2^25" mean?
The notation "2^25" represents the number 2 raised to the 25th power.
What does the "o" symbol mean in the equation?
The "o" symbol in the equation represents degrees, indicating that the trigonometric functions are being calculated in degrees rather than radians.
What method will be used to prove the equation?
The equation will be proven using the double angle identity for sine, which states that sin(2x) = 2sin(x)cos(x).
What is the significance of proving this equation?
Proving this equation shows the relationship between sine and cosine for angles that are double each other, and reinforces a fundamental concept in trigonometry.
