Can you prove that P, Q, or L [Propositional Logics]
  • Thread starter Shaitan00
In summary, using the given equations, it can be concluded that if Cleopatra is either venerated or feared, she must also be a queen. It is not possible to prove that Cleopatra was powerful without using resolution-refutation. However, it can be proven that she was a leader and a queen. This can be determined by the fact that if Cleopatra is either venerated or feared, she must also be a queen, and if she is a queen, she is also a leader.
Shaitan00
I was given the following text:
If Cleopatra was powerful, then she was venerated but if she was not powerful, then she was not venerated and she was feared. If Cleopatra was either venerated or feared, then she was a queen. Cleopatra was a leader if she was a queen.
P = Cleopatra was Powerful
V = Cleopatra was Venerated
F = Cleopatra was Feared
Q = Cleopatra was a Queen
L = Cleopatra was a Leader
I am being asked if I can prove that Cleopatra was Powerful? A Leader? A Queen? (without using resolution-refutation).
Propositional clauses:
1. P -> V
2. !P -> (!V and F)
3. (V or F) -> Q
4. Q -> L
CNF Format (shouldn’t be needed but incase):
1. ! P or V
2a. (P or !V)
2b. (P or F)
3a. (!V or Q)
3b. (!F or Q)
4. !Q or L
From here I was able, with resolution-refutation, to determine that we cannot prove P but we should be able to prove Q and L… After that I am completely stuck on how to proceed as I am not allowed to prove the question with that approach – only to help me see what answers I should get…
I assume I must either use Forward-Chaining or Backward-Chaining to solve the problems – but no knowledge is given, only implications – so how is one supposed to use either? In all my readings usually we would be given something like F=True (knowledge) or something similar and the chaining would come down to that – but with only implications I can’t see how anything can be proven…
All my attempts (and there have been many) have only added to my confusion.
Any help/hints would be greatly appreciated.
Thanks,
Keep in mind that (P or !P) is always true. What does that say about 1, about 2? One has to be true, right? What result do you get if 1 is true? how about 2? How about V and F? Does one of them always have to be true? If so what does that say about Q? how about L?
Is it accurate to say the following:
The case contradicting P is if Cleopatra is neither powerful, venerate or feared, then the premises don't imply that Cleaopatra is powerful
Thanks,
No.
You don't know if P is true or not. All you know is that if P is true then V is true and if P is false then V is false and F is true. You get that from the two equations: P -> V and the equation !P -> (!V and F). However by the rules of propositional logic you know that either P is true or !P is true. This means that either V is true or F is true.
So since you know that V is true or F is true, what do you know about Q and L?
FAQ: Can you prove that P, Q, or L [Propositional Logics]
1. Can you explain the concept of propositional logic?
Propositional logic is a branch of mathematical logic that deals with the study of logical relationships between propositions, which are statements that are either true or false. It uses logical operators, such as AND, OR, and NOT, to manipulate propositions and determine their truth values.
2. How can you prove a statement using propositional logic?
In propositional logic, a statement can be proven by constructing a logical argument that uses premises (assumptions) and logical rules to arrive at a conclusion. The validity of the argument can then be checked using truth tables or other methods of proof.
3. Is it possible to prove every statement using propositional logic?
No, it is not possible to prove every statement using propositional logic. Some statements may require more advanced logical systems, such as first-order logic, to be proven.
4. Can you give an example of a statement that can be proved using propositional logic?
An example of a statement that can be proved using propositional logic is: If it is raining (P), then the ground is wet (Q). This statement can be represented as P → Q and can be proven using logical rules and truth tables.
5. How is propositional logic used in real-world applications?
Propositional logic is used in various real-world applications, such as computer programming, artificial intelligence, and automated reasoning. It is also used in the field of philosophy to analyze arguments and determine their validity.
