MHB Can you prove the combinatorics challenge and find the value of |S_n-3T_n|?
The discussion focuses on proving that |S_n - 3T_n| = 2, where S_n is the sum of binomial coefficients from 0 to 3n and T_n sums every third binomial coefficient up to n. A solution is presented using the function f(x) defined as the sum of binomial coefficients multiplied by x^k. By evaluating f at 1 and the complex cube roots of unity, it is shown that S_n - 3T_n simplifies to -2. The conversation highlights the collaborative effort in finding multiple solutions to the combinatorial challenge.
anemone
MHB
POTW Director
For $n=1,2,...,$ set $$S_n=\sum_{k=0}^{3n} {3n\choose k}$$ and $$T_n=\sum_{k=0}^{n} {3n\choose 3k}$$.
Prove that $|S_n-3T_n|=2$.
Mathematics news on Phys.org
My solution:
For the first sum, we may simply apply the binomial theorem to obtain the closed form:
$$S_n=\sum_{k=0}^{3n}{3n \choose k}=(1+1)^{3n}=8^n$$
For the second sum, I looked at the first 5 values:
$$T_1=2,\,T_2=22,\,T_3=170,\,T_4=1366,\,T_5=10922$$
and determined the recursion:
$$T_{n+1}=7T_{n}+8T_{n-1}$$
The characteristic equation for this recursion is:
$$r^2-7r-8=(r+1)(r-8)=0$$
and so the closed form is:
$$T_{n}=k_1(-1)^n+k_28^n$$
Using the initial values to determine the parameters, we may write:
$$T_{1}=-k_1+8k_2=2$$
$$T_{2}=k_1+64k_2=22$$
Adding the two equations, we find:
$$72k_2=24\implies k_2=\frac{1}{3}\implies k_1=\frac{2}{3}$$
Hence:
$$T_{n}=\frac{1}{3}\left(2(-1)^n+8^n \right)$$
And so we find:
$$\left|S_n-3T_n \right|=\left|8^n-3\left(\frac{1}{3}\left(2(-1)^n+8^n \right) \right) \right|=\left|8^n-2(-1)^n-8^n \right|=\left|2(-1)^{n+1} \right|=2$$
Shown as desired.
MarkFL said:
My solution:
Hence:
And so we find:
Shown as desired.
Hey thanks for participating MarkFL! And I'm so impressed that you were so fast in cracking this problem!
Define $f(x)=\sum_{k=0}^{3n}{3n\choose k}x^k$.
Then $f(1)+f(\omega)+f(\omega^2)=3T_n$, where $\omega$ is a complex cube root of unity. Note that $f(1)=S_n$. So we get $S_n-3T_n=-[(1+\omega)^{3n}+(1+\omega^2)^{3n}]=-2$
Hi caffeinemachine,
Thanks for participating and I really appreciate you adding another good solution to this problem and my thought to solve this problem revolved around the idea that you used too!:)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
