Can you prove the definite value of $f(x)$?
  • MHB
  • Thread starter Albert1
In summary, the conversation is about proving the definite value (constant) of the function $f(x)=\dfrac {sin \,3x}{sin\, x}-\dfrac {cos\, 3x}{cos \,x}$ and discussing the conditions for which $f(x)$ is undefined.
Albert1
1,221
prove the value of $f(x)$ is always definite
Mathematics news on Phys.org
of course :$sin\,x\,\times cos\,x \neq 0$
if $sin\,x\times \,cos\,x=0$ then $f(x)$ is meaningless
hint :$sin\,3x=?\,\,\,$ $cos\,3x=?$
I do not know what you mean by definiten but if you mean constant then
$\dfrac {sin \,3x}{sin\, x}-\dfrac {cos\, 3x}{cos \,x}$
= $\dfrac {sin \,3x\cos\, x-cos\, 3x\sin\, x}{cos \,x\sin\,x }$
= $\dfrac {sin \,2x}{cos \,x\sin\,x }$
= $\dfrac {2 sin \,2x}{2 cos \,x\sin\,x }$
= $\dfrac {2 sin \,2x}{\sin\,2x }$
= 2
which is constant
= 2
which is constant
yes the definite value (constant) of f(x) is 2
Here's another way to proceed:
We are given:
\(\displaystyle f(x)=\frac{\sin(3x)}{\sin(x)}-\frac{\cos(3x)}{\cos(x)}\)
Combine terms:
\(\displaystyle f(x)=\frac{\sin(3x)\cos(x)-\cos(3x)\sin(x)}{\sin(x)\cos(x)}\)
In the numerator, apply angle-difference identity for sine and in the denominator apply double-angle identity for sine:
\(\displaystyle f(x)=\frac{\sin(3x-x)}{\dfrac{1}{2}\sin(2x)}=2\)
another solution:
$\dfrac {sin\,3x}{sin\,x}-\dfrac {cos\,3x}{cos\,x}$
$=\dfrac {3sin\,x-4sin^3x}{sin\,x}-\dfrac {4cos^3\,x -3cos\,x}{cosx}$
$=6-4(sin^2x+cos^2x)=6-4=2$
FAQ: Can you prove the definite value of $f(x)$?
What does "f(x)" mean?
"f(x)" is a notation used in mathematics to represent a function. It stands for "function of x", where "x" is the independent variable and "f(x)" is the dependent variable.
How do you find the value of f(x)?
To find the value of f(x), you need to substitute the value of the independent variable (x) into the function and solve for the dependent variable (f(x)). For example, if the function is f(x) = 2x + 1 and x = 3, then f(3) = 2(3) + 1 = 7.
What is the purpose of finding f(x)?
Finding f(x) allows us to understand the relationship between the independent variable and the dependent variable in a function. It helps us analyze and make predictions about the behavior of the function.
How do you graph f(x)?
To graph f(x), you need to plot points on a coordinate plane using the values of the independent and dependent variables. You can also use the slope and y-intercept of the function to plot a straight line.
Can you find f(x) for any function?
Yes, f(x) can be found for any function as long as the function is well-defined and has a definite output for each input. However, some functions may be more complex and require more advanced methods to find their values.
