Can You Prove This Integer Property in Real Numbers?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, the Integer Property in Real Numbers states that the product of two integers will always result in an integer. It is important to prove this property as it is a fundamental concept in mathematics and serves as the basis for many other calculations. The Integer Property can be proven using multiplication and division rules, as well as mathematical induction. Examples of the Integer Property in action include 2 x 3 = 6 and -5 x 4 = -20. This property differs from the Rational Property in that it only applies to whole numbers and does not include division.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
The real numbers $x,\,y$ and $z$ are such that $x^2+y^2=2z^2$, $x\ne y,\,z\ne -x,\,z\ne -y$.
Prove that \(\displaystyle \frac{(x+y+2z)(2x^2-y^2-z^2)}{(x-y)(x+z)(y+z)}\) is an integer.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. kaliprasad
2. Opalg
Solution from kaliprasad:
We have $4x^2- 2y^2 -2z^2 = 4x^2 - 2y^2 - (x^2 +y^2) = 3(x^2-y^2) = 3(x-y)(x+y)\cdots(1)$ (by the given relation)
Now the numerator
$(x+y+2z)(2x^2-y^2-z^2)$
$= \frac{3}{2}(x+y + 2z)(x+y)(x-y)$
$= \frac{3}{2}((x+y)^2 + 2z(x+y))(x-y)$
$= \frac{3}{2}(x^2+y^2+ 2xy + 2z(x+y))(x-y)$
$= \frac{3}{2}(2z^2 + 2xy + 2z (x+y))(x-y)$ using $x^2 + y ^2 = 2z^2$
$= 3(z^2+ xy + zx + zy)(x-y)$
$= 3(z+ x)(z+ y)(x-y)$
Hence $\dfrac{(x+y+2z)(2x^2-y^2-z^2)}{(x-y)(x+z)(y+z)} = \dfrac{3(x-y)(x+z)(y+z)}{(x-y)(x+z)(y+z)} = 3$, which is an integer.
Alternate solution from Opalg:
Let $$A = (x+y+2z)(2x^2 - y^2 - z^2) = (2x^3 - y^3 - 2z^3) + (2x^2y - 2y^2z - z^2x) + (4x^2z - y^2x - z^2y),$$ $$B = (x-y)(x+z)(y+z) = (x^2y - y^2z + z^2x) + (x^2z - y^2x - z^2y).$$ If $x^2 + y^2 = 2z^2$ then $$x^3 = x\cdot x^2 = x(2z^2-y^2) = 2z^2x - y^2x,$$ and similarly $$y^3 = 2z^2y - x^2y,$$ $$2z^3 = x^2z + y^2z.$$ Substitute those expressions for $x^3$, $y^3$, $2z^3$ into $A$ to get $$\begin{aligned}A &= 2(2z^2x - y^2x) - (2z^2y - x^2y) - (x^2z + y^2z) + (2x^2y - 2y^2z - z^2x) + (4x^2z - y^2x - z^2y) \\ &= (3x^2y - 3y^2z + 3z^2x) + (3x^2z - 3y^2x - 3z^2y) = 3B. \end{aligned}$$ The other conditions of the problem say that $B\ne0$, so we can conclude that $\dfrac AB = 3.$
FAQ: Can You Prove This Integer Property in Real Numbers?
What is the Integer Property in Real Numbers?
The Integer Property in Real Numbers states that any integer multiplied by another integer will always result in an integer. This means that the product of two whole numbers will always be a whole number.
Why is it important to prove the Integer Property?
Proving the Integer Property in Real Numbers is important because it is a fundamental concept in mathematics. It helps us understand the behavior of numbers and their relationships with each other. Additionally, it serves as the basis for many other mathematical concepts and calculations.
How can the Integer Property be proven?
The Integer Property can be proven using the rules of multiplication and division, as well as the definitions of integers and real numbers. It can also be proven using mathematical induction, which is a method of proving statements for all natural numbers.
What are some examples of the Integer Property in action?
Some examples of the Integer Property in action are: 2 x 3 = 6, -5 x 4 = -20, and 9 x 0 = 0. In each of these examples, the product of two integers results in another integer.
How does the Integer Property differ from the Rational Property?
The Integer Property and the Rational Property are similar in that they both deal with the multiplication of numbers. However, the Integer Property only applies to whole numbers, while the Rational Property applies to all numbers (including fractions and decimals). Additionally, the Rational Property also includes the concept of division, while the Integer Property does not.
