I Can you put out a fuse (fire) with a laser?
Using a laser to extinguish a fuse or stop combustion is theoretically possible, but practically unfeasible. While a powerful laser can melt a fusible link, it adds energy to the combustion process, likely accelerating it rather than halting it. Laser cooling is ineffective on hot gases and only applies to atoms at near absolute zero temperatures. Some suggest that laser light could potentially push oxygen away from a burning fuse, but this would require an extremely expensive and powerful laser system. Overall, the concept remains more of a theoretical exploration than a viable firefighting method.
J3J33J333
TL;DR Summary
I was wondering you if you could use a laser to put out a fuse or to stop combustion?
I was wondering you if you could use a laser to put out a fuse or to stop combustion? Could you use some form of laser/laser cooling to put out an explosion mid-explosion?
Under what principle?
Any laser with sufficient power could melt a fusible link. Lasers are used to cut thick sheets of steel.
https://en.wikipedia.org/wiki/Laser_cutting
A laser adds energy to the system, so it is unlikely to be able to stop combustion or halt an explosion. It would probably only increase the rate of the process.
Lasers can only cool things like single atoms that are held in a trap, at temperatures close to absolute zero. The laser can stimulate removal of the last quantum of energy from the trapped atom.
https://en.wikipedia.org/wiki/Laser_cooling
I thought he meant the kind of fuse on dynamite. A rapid oxidation reaction.
In principle? Yes.
But just shining any old laser at a fuse will do absolutely nothing.
J3J33J333 said:
Summary: I was wondering you if you could use a laser to put out a fuse or to stop combustion?
I wish. Laser cooling will not work on room temperature gases, much less hot combustion gases. Our "explosions" that get studied in atomic physics experiments occur at or below a thousandth or even a millionth of a degree kelvin above absolute zero.
I say it is possible in principle to stop combustion because radiative forces on molecules has been demonstrated (several times, like this example). You could use laser light to push the oxygen away from the burning fuse. It would just be a very, very expensive laser system.
You seem to be thinking along the lines of blowing out oil well fires with dynamite. I'd have to ask what scale of fire are you actually considering and what power of laser could be involved. Any laser pulse would need sufficient Energy to cause an 'explosion' to blast away enough oxygen from the fire to stop it burning and allow it all to cool down before it could re-ignite (fire triangle). So it's not just the Peak Power of the laser that counts (which could easily be GW) but the total Energy in a shortish interval. We could be talking in terms of a military weapon which could vaporise parts of an incoming missile.
As has been pointed out already, 'Laser cooling' is an entirely different (quantum) effect.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
