Maija Brandt
- 4
Is separating hydrogen and oxygen molecules possible? If so, how?
Are you talking about separating the two gases, or are you talking about decomposing water to produce hydrogen and oxygen?Maija Brandt said:Is separating hydrogen and oxygen molecules possible? If so, how?
Is this related to your other thread?Maija Brandt said:Is separating hydrogen and oxygen molecules possible? If so, how?
Maija Brandt said:I’m working on an idea that I have, and I was wondering if there was something that could repel hydrogen. Not water, not oxygen, just hydrogen. Thanks!
Yes, this is.berkeman said:Is this related to your other thread?
Decomposing water.Chestermiller said:Are you talking about separating the two gases, or are you talking about decomposing water to produce hydrogen and oxygen?
Electrolysis. Just be careful with the Hydrogen gas that you generate. You put a lot of energy into the water to get it to split into Hydrogen and Oxygen...Maija Brandt said:Decomposing water.
it's a common process,Maija Brandt said:Decomposing water.
Don’t do this without professional supervision and a safety audit.Maija Brandt said:Decomposing water.
Chestermiller said:Don’t do this without professional supervision and a safety audit.
I believe that this is why my chemistry set experiment use muratic acid with one anode zinc and the other I can't recall. At ten, I wasn't using a high voltage.diogenesNY said:Might be worth noting that it is pretty expensive (energy-wise) to separate water into hydrogen and oxygen... that is to say it costs more energy to separate them than one can reasonably expect to get back by burning one, the other or both.
On the other hand, separating hydrogen from hydrocarbons is a much less costly procedure, and is being done with membranes (Palladium, alloys, and now even some stainless steel alloys - experimentally) ... This technology is seen as having serious potential for hydrogen generation for use in fuel cells. This sort of thing is in its early stages, but is currently being used aboard some US Navy submarines for power generation.
diogenesNY
To separate hydrogen and oxygen molecules, you can use a process called electrolysis. This involves passing an electric current through water, which breaks down the water molecules into hydrogen and oxygen gas.
Yes, it is possible to separate hydrogen and oxygen molecules without electricity. This can be done through a process called photolysis, where water molecules are broken down using sunlight as a source of energy.
The equipment needed to separate hydrogen and oxygen molecules through electrolysis includes a power source, two electrodes (usually made of metal), and a container of water. The electrodes are connected to the power source and placed in the water, which is then subjected to an electric current.
The time it takes to separate hydrogen and oxygen molecules through electrolysis depends on the amount of electricity used and the size of the electrodes. Generally, it takes a few minutes to produce a noticeable amount of gas, but a larger amount may take longer.
Separated hydrogen and oxygen molecules have various uses, including as a fuel source for vehicles, in the production of chemicals, and in the production of electricity through fuel cells. Hydrogen gas can also be used in the food industry for packaging and preserving food.
