Can You Simplify This Trigonometric Expression?
  • MHB
  • Thread starter anemone
In summary, the topic of POTW #486 is evaluating trigonometric expressions and it will be released on October 11th, 2021. The purpose of evaluating trigonometric expressions is to simplify and solve complex equations involving trigonometric functions. Prior knowledge of trigonometric functions and identities is necessary to solve POTW #486. Solutions can be checked using a calculator or by seeking assistance from a math teacher or tutor.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Evaluate $\dfrac{1}{\sin 6^{\circ}}+\dfrac{1}{\sin 78^{\circ}}-\dfrac{1}{\sin 42^{\circ}}-\dfrac{1}{\sin 66^{\circ}}$.
Congratulations to lfdahl for his correct solution (Cool) , which you can find below:
\[\frac{1}{\sin 6^{\circ}}+\frac{1}{\sin 78^{\circ}}-\frac{1}{\sin 42^{\circ}}-\frac{1}{\sin 66^{\circ}} \\\\\\=\frac{\sin 66^{\circ}-\sin 6^{\circ}}{\sin 6^{\circ} \sin 66^{\circ}}+\frac{\sin 42^{\circ}-\sin 78^{\circ}}{\sin 42^{\circ} \sin 78^{\circ}} \\\\\\= \frac{2\sin \left ( \frac{66^{\circ}-6^{\circ}}{2} \right )\cos \left ( \frac{66^{\circ}+6^{\circ}}{2}\right )}{\frac{1}{2}\left ( \cos (66^{\circ}-6^{\circ}) -\cos \left ( 66^{\circ}+6^{\circ}\right )\right )}+\frac{2\sin \left ( \frac{42^{\circ}-78^{\circ}}{2} \right )\cos \left ( \frac{42^{\circ}+78^{\circ}}{2}\right )}{\frac{1}{2}\left ( \cos (42^{\circ}-78^{\circ}) -\cos \left ( 42^{\circ}+78^{\circ}\right )\right )} \\\\\\=\frac{2 \sin 30^{\circ}\cos 36^{\circ}}{\frac{1}{2}\left ( \cos 60^{\circ}-\cos 72^{\circ} \right )}-\frac{2 \sin 18^{\circ}\cos 60^{\circ}}{\frac{1}{2}\left ( \cos 36^{\circ}-\cos 120^{\circ} \right )} \\\\\\=\underbrace{\frac{4\cos 36^{\circ}}{1-\cos(2\cdot 36^{\circ})}}_A\underbrace{-\frac{4\cos(2\cdot 36^{\circ})}{1+2\cos 36^{\circ}}}_B\]
Let $\alpha = \cos 36^{\circ}$:
\[A = \frac{4\alpha }{3-4\alpha ^2}, \;\;\; B = \frac{4-8\alpha ^2}{1+2\alpha }\]
It is not hard to show*, that: $\alpha = \frac{1+\sqrt{5}}{4}$. Inserting this in $A$ and $B$ yields:
\[A = \frac{2+2\sqrt{5}}{3-\sqrt{5}},\;\;\;B = \frac{2-2\sqrt{5}}{3+\sqrt{5}}\]
Finally, we get: \[A + B = 8.\]
(*). I use the well-known trick to calculate $\sin 18^{\circ}$ first:
Put $Y = 18^{\circ}$.
Then $\sin 2Y = \cos 3Y \rightarrow 2\sin Y\cos Y = 4\cos^3Y-3\cos Y \rightarrow \\\\ 2 \sin Y = 4(1-\sin^2Y) -3 \rightarrow 4\sin^2Y +2\sin Y-1 = 0$ - the solution of which is: $\sin Y = \sin 18^{\circ} = \frac{\sqrt{5}-1}{4}$.
With $\cos 36^{\circ} = 1 – 2 \sin^2 18^{\circ}$ we immediately have the result.
FAQ: Can You Simplify This Trigonometric Expression?
What is the purpose of evaluating trigonometric expressions?
Evaluating trigonometric expressions allows us to find the numerical value of a given expression involving trigonometric functions such as sine, cosine, and tangent. This is useful in various fields of science and engineering, including physics, astronomy, and navigation.
How do I evaluate a trigonometric expression?
To evaluate a trigonometric expression, you need to use the values of the trigonometric functions for specific angles, which can be found in a trigonometric table or calculated using a calculator. Then, substitute these values into the expression and simplify it using algebraic rules.
What are the common trigonometric identities used in evaluating expressions?
Some common trigonometric identities used in evaluating expressions include the Pythagorean identities, double angle identities, half angle identities, and sum and difference identities. These identities help simplify complex expressions and make them easier to evaluate.
Can I use a calculator to evaluate trigonometric expressions?
Yes, you can use a calculator to evaluate trigonometric expressions. Most scientific calculators have built-in trigonometric functions that can be used to find the numerical value of a given expression. However, it is important to understand the concepts and principles behind trigonometric functions to use a calculator effectively.
What are some real-life applications of evaluating trigonometric expressions?
Trigonometric expressions are used in various real-life applications, such as calculating the height of a building or mountain using the angle of elevation, determining the distance between two points using the angle of depression, and predicting the tides and ocean currents using trigonometric functions. They are also used in fields like engineering, architecture, and surveying.
