Can you solve (a-bx)y'+(c-dx)y-e=0 with a,b,c,d,e constants?
In summary, the conversation discusses a differential equation with constants a, b, c, d, and e and the difficulties of solving it using laplace transformation. The speaker also suggests using an integrating factor to solve the equation, but notes that it may result in a non-analytical solution.
JanisEB
I'm having trouble solving the differential equation (a-bx)y'+(c-dx)y-e=0 with a,b,c,d,e constants.
I tried laplace transforming it, but then I end up with yet another differential equation in the laplace domain because of the xy and xy' terms.
So what methods have you ruled out?
You really want to avoid using "d" as a constant label in differential equations.
The DE is 1st order, linear, and has form:
y' + p(x)y = q(x) if you put p = (c-dx)/(a-bx) and q=e/(a-bx)
More generally: f(x)y' + g(x)y = e
Have you looked for an integrating factor? - watch for funny integrals like the gamma function.
Likes Ravikant Rajan
Thanks a lot! That works, but indeed I end up with a funny integral that does not have an analytical solution. I was hoping for an elegant solution, but I'll have to rely on my computer then.
Related to Can you solve (a-bx)y'+(c-dx)y-e=0 with a,b,c,d,e constants?
1. What is the general solution to the given equation?
The general solution to this equation is y = Ce(ax2+bx+c)/d, where C is a constant and a, b, c, d are the given constants.
2. How do you determine the particular solution to this equation?
The particular solution can be found by using the method of undetermined coefficients or variation of parameters, depending on the form of the equation.
3. Can this equation be solved using separation of variables?
No, this equation cannot be solved using separation of variables because it is not in the form of dy/dx = f(x)g(y).
4. Is it possible to solve this equation numerically?
Yes, it is possible to solve this equation numerically using methods such as Euler's method or Runge-Kutta method.
5. What are the applications of solving this type of equation?
This type of equation is commonly used in physics, engineering, and other scientific fields to model physical phenomena such as population growth, chemical reactions, and heat transfer.
  • Differential Equations
