MHB Can You Solve for m and n in x^2+mx+n=0 with Only One Possible Value for x?
  • Thread starter Thread starter mathdad
In the equation x^2 + mx + n = 0, with -3 as the only root, the values of m and n can be determined through various methods. Using the vertex form and the discriminant, it is established that m must equal 6 and n must equal 9. The discriminant must be zero for a quadratic with a single root, leading to the equations m^2 - 4n = 0 and 9 - 3m + n = 0. Both approaches confirm that the solution is consistent, resulting in the pair (m, n) = (6, 9). This problem illustrates the relationship between the coefficients of a quadratic and its roots effectively.
mathdad
My friend and I love to challenge each other from time to time when we come across a new question in a textbook or online. Here is the question he found. In the equation x^2+mx+n=0, m and n are integers. The only possible value for x is -3. What is the value of m and n?
I am thinking discriminant: b^2 - 4ac, where a = 1, b = m and c = n.
Correct approach?
Mathematics news on Phys.org
Correct approach?
What I would do is from the given information, we know:
$$x^2+mx+n=(x+3)^2$$
Expand the RHS, and then equate coefficients to determine $m$ and $n$.
Now, you could use the discriminant...what must its value be? Can you determine another equation with $m$ and $n$ using the given root?
How about this solution?
Let x = -3
x +3 = 0
(x+3)^2 = x^2 + 6x + 9
m = 6; n = 9
Correct?
Let x = -3
x +3 = 0
m = 6; n = 9
Correct?
Yep. :D
Let's look at using the discriminant as you initially posted.
If a quadratic has only one root, then its discriminant must be zero, and so we obtain:
$$m^2-4n=0$$
Using the given root $x=-3$, we also have:
$$9-3m+n=0$$
If we multiply this by 4, we get:
$$36-12m+4n=0$$
The first equation (regarding the discriminant) implies $4n=m^2$, and we have:
$$m^2-12m+36=(m-6)^2=0\implies m=6\implies n=9$$
Now, we could also reason that a quadratic having only one root, will have its axis of symmetry at that root. Recall the axis of symmetry for the general quadratic $ax^2+bx+c$ is given by:
$$x=-\frac{b}{2a}$$
So we would have:
$$-\frac{m}{2}=-3\implies m=6$$
And then using either the discriminant, or the value of the quadratic at the root, we can easily find $n=9$.
We could also write the quadratic in vertex form:
$$x^2+mx+n=\left(x^2+mx+\frac{m^2}{4}\right)+n-\frac{m^2}{4}=\left(x+\frac{m}{2}\right)^2+\frac{4n-m^2}{4}$$
We know the vertex must be at $(-3,0)$, and so this gives us:
$$\frac{m}{2}=3$$
$$\frac{4n-m^2}{4}=0$$
And from this we easily find:
$$(m,n)=(6,9)$$
Interesting question for sure.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
