Can You Solve the Equation with Logs: $\log_2 (\cos x)=2\log_3 (\cot x)$?
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, to solve the equation $\log_2(\cos x)=2\log_3(\cot x)$, we need to simplify it using logarithm rules and then equate the exponents to solve for $x$. There are infinitely many possible solutions, but we typically only consider solutions within a specific interval. This equation can be solved algebraically, but it may be difficult without the use of technology or approximation methods. There are restrictions on the values of $x$ that satisfy the domains of the logarithmic functions involved. To check solutions, you can plug them back into the original equation or graph the two sides separately to find the points of intersection.
anemone
MHB
POTW Director
3,883
115
Solve the equation $\log_2 (\cos x)=2\log_3 (\cot x)$.
_______________________________________________________________________________________________________
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week's problem. :(
You can find the proposed solution below:
Before we get started, notice that there are two restrictions set for the given equation:
1. LHS tells us $\cos x>0$ and
2. RHS tells us $\sin x>0$.
This could be turned into a more valuable info if we consider only the domain for $[0,\,2\pi]$, since the function $y=\log_2 (\cos x)$ and $y=2\log_3 (\cot x)$ on both sides are periodic functions with the period of $2\pi$.
This implies we need to only consider the interval $\left(0,\,\dfrac{\pi}{2}\right)$.
We could rewrite the given equation by using the change-of-base formula so that both logarithms have the same base.
$\dfrac{\log_{10} (\cos x)}{\log_{10} 2}=2\dfrac{\log_{10} (\cot x)}{\log_{10} 3}$
$\log_{10} 3\log_{10} (\cos x)=2\log_{10} 2\log_{10} (\cot x)$
$\log_{10} 3\log_{10} (\cos x)=2\log_{10} 2\log_{10} \left(\dfrac{\cos x}{\sin x}\right)$
$\log_{10} 3\log_{10} (\cos x)=2\log_{10} 2\log_{10} \cos x-2\log_{10} 2\log_{10} \sin x$
$2\log_{10} 2\log_{10} \sin x=2\log_{10} 2\log_{10} \cos x-\log_{10} 3\log_{10} (\cos x)$
$2\log_{10} 2\log_{10} \sin x=\log_{10} \cos x(2\log_{10} 2-\log_{10} 3)$
Notice that the function on the LHS is continuous increasing while the function on the RHS is continuous decreasing over the interval $\left(0,\,\dfrac{\pi}{2}\right)$.
We can conclude based on that observation that there exists only one intersection point for the both functions in that interval, and it's not hard to see $x=\dfrac{\pi}{3}$ is the answer.
The solution for this problem is hence $x=\dfrac{\pi}{3}+2k\pi$, where $k\in\mathbb{Z}$.
FAQ: Can You Solve the Equation with Logs: $\log_2 (\cos x)=2\log_3 (\cot x)$?
How do I solve the equation $\log_2(\cos x)=2\log_3(\cot x)$?
To solve this equation, we first need to use logarithm rules to simplify the equation. We can rewrite $\log_2(\cos x)$ as $\log_2(\cos x)^2$ and $\log_3(\cot x)$ as $\log_3(\cot x)^2$. This gives us the equation $\log_2(\cos x)^2=2\log_3(\cot x)^2$. Then, using the power rule of logarithms, we can rewrite this as $\log_2(\cos x)^2=\log_3(\cot x)^4$. From here, we can equate the exponents and solve for $x$.
What are the possible solutions to the equation $\log_2(\cos x)=2\log_3(\cot x)$?
There are infinitely many solutions to this equation, as the trigonometric functions $\cos x$ and $\cot x$ have an infinite number of solutions. However, when solving for $x$, we will typically only consider solutions within a certain interval, such as $0\leq x<2\pi$.
Can this equation be solved algebraically?
Yes, this equation can be solved algebraically using logarithm rules and basic algebraic manipulations. However, the resulting equation may be difficult to solve for $x$ without the use of technology or approximation methods.
Are there any restrictions on the values of $x$ in this equation?
Yes, there are restrictions on the values of $x$ in this equation. The values of $x$ must satisfy the domains of the logarithmic functions involved, which in this case are $\cos x>0$ and $\cot x>0$. Additionally, we may choose to restrict the values of $x$ to a specific interval, as mentioned in question 2.
How can I check my solutions to this equation?
To check your solutions to this equation, you can plug them back into the original equation and see if they satisfy the equation. You can also graph the two sides of the equation separately and see where they intersect, as this will give you the solutions to the equation.
