Can You Solve the Sum of Reciprocals for the Fourth Root Function?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the "Sum of Reciprocals from Square Root Function" is a mathematical function that calculates the sum of the reciprocals of a set of numbers, where each number is the square root of the corresponding natural number. It is calculated by finding the square roots of the numbers, taking the reciprocal, and adding them together. This function is used in mathematics to find the sum of numbers related to the square root function and can be applied in various fields such as physics, engineering, and finance. However, it may not be applicable to all sets of numbers and may only provide an approximation for certain problems.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Evaluate \(\displaystyle \sum_{i=1}^{1995}\dfrac{1}{f(i)}\), given that \(\displaystyle f(k)\) be the integer closest to \(\displaystyle \sqrt[4]{k}\).
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week's problem.(Sadface)
You can find the suggested solution below:
The largest integer with fourth root closest to $n$ is \(\displaystyle \left\lfloor{\left(n+\dfrac{1}{2}\right)^4}\right\rfloor\) since
\(\displaystyle \begin{align*}\left\lfloor{\left(n+\dfrac{1}{2}\right)^4}\right\rfloor&=\left\lfloor{n^4+2n^3+\dfrac{3}{2}n^2+\dfrac{1}{2}n+\dfrac{1}{16}}\right\rfloor\\&=\left\lfloor{n^4+2n^3+\dfrac{1}{2}\left(3n^2+k\right)+\dfrac{1}{16}}\right\rfloor\\&=n^4+2n^3+\dfrac{1}{2}\left(3n^2+n\right)\text{since } 3n^2+n\text{ is even}\end{align*}\)
$\therefore$ the number of integers with fourth root closest to $n$ is:
\(\displaystyle \begin{align*}\left\lfloor{\left(n+\dfrac{1}{2}\right)^4}\right\rfloor-\left\lfloor{\left((n-1)+\dfrac{1}{2}\right)^4}\right\rfloor&=\left\lfloor{\left(n+\dfrac{1}{2}\right)^4}\right\rfloor-\left\lfloor{\left(n-\dfrac{1}{2}\right)^4}\right\rfloor\\&=\left(n^4+2n^3+\dfrac{1}{2}\left(3n^2+n\right)\right)-\left(n^4-2n^3+\dfrac{1}{2}\left(3n^2-n\right)\right)\\&=4n^3+n\end{align*}\)
That is, $f(k)=n$ for $4n^3+n$ (consecutive) values of $k$.
Since \(\displaystyle f(1995)=7,\,\sum_{n=1}^{6}(4n^3+n)=1785\) and $f(1786)=f(1787)=\cdots=f(1995)=7$, it follows that
\(\displaystyle \begin{align*}\sum_{i=1}^{1995}\dfrac{1}{f(i)}&=\sum_{i=1}^{1785}\dfrac{1}{f(i)}+\dfrac{210}{7}\\&=\sum_{n=1}^{6}\left(\frac{4n^3+n}{n}\right)+30\\&=\sum_{n=1}^{6}\left(4n^2+1\right)+30\\&=400\end{align*}\)
FAQ: Can You Solve the Sum of Reciprocals for the Fourth Root Function?
What is the "Sum of Reciprocals from Square Root Function"?
The "Sum of Reciprocals from Square Root Function" refers to a mathematical function that calculates the sum of the reciprocals (1/x) of a set of numbers, where each number is the square root of the corresponding natural number.
How is the "Sum of Reciprocals from Square Root Function" calculated?
The "Sum of Reciprocals from Square Root Function" is calculated by first finding the square roots of a set of natural numbers, then taking the reciprocal of each square root. Finally, the reciprocals are added together to get the total sum.
What is the purpose of the "Sum of Reciprocals from Square Root Function"?
The "Sum of Reciprocals from Square Root Function" is used in mathematics to find the sum of a series of numbers that have a relationship to the square root function. It can also be used to approximate the value of certain mathematical constants, such as the Euler-Mascheroni constant.
What are some real-life applications of the "Sum of Reciprocals from Square Root Function"?
The "Sum of Reciprocals from Square Root Function" can be used in various fields such as physics, engineering, and finance. For example, it can be used to calculate the total resistance of a series of parallel electrical circuits or to estimate the total cost of a series of payments with varying interest rates.
Are there any limitations to the "Sum of Reciprocals from Square Root Function"?
The "Sum of Reciprocals from Square Root Function" may not be applicable to all sets of numbers, as it specifically deals with numbers that are square roots of natural numbers. Additionally, the function may not be able to provide an exact solution for certain mathematical problems and may only provide an approximation.
