Can You Solve This Advanced Algebra Puzzle?
  • MHB
  • Thread starter anemone
In summary, evaluating an equation with positive real numbers allows us to find the value of the variable or unknown quantity in the equation, which is crucial for solving real-world problems and making accurate predictions. To evaluate an equation with positive real numbers, we need to substitute the values given for the variables and follow the order of operations. Positive real numbers are numbers greater than zero, while negative real numbers are numbers less than zero, and they are represented differently in equations. It is possible to evaluate an equation with both positive and negative real numbers, as long as we keep track of the signs and follow the order of operations. Finally, using positive real numbers in evaluating equations is important because they represent meaningful quantities and provide valuable insights into real-world situations.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
If $x$ and $y$ are positive real numbers that satisfy the equation $x+4\sqrt{xy}-2\sqrt{x}-4\sqrt{y}+4y=3$, evaluate $\dfrac{\sqrt{x}+2\sqrt{y}+2014}{4-\sqrt{x}-2\sqrt{y}}$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution!(Cool)
1. kaliprasad
2. castor28
3. MegaMoh
4. lfdahl
5. Greg
Solution from Greg:
Note that the L.H.S. of the given equation factors as $(\sqrt x+2\sqrt y)(\sqrt x+2\sqrt y-2)$.
Setting $u=\sqrt x+2\sqrt y$ we obtain the quadratic $u^2-2u-3=(u-3)(u+1)=0$ and this implies that $\sqrt x+2\sqrt y=3$.
Thus we may conclude that $\frac{\sqrt{x}+2\sqrt{y}+2014}{4-\sqrt{x}-2\sqrt{y}}=2017$
FAQ: Can You Solve This Advanced Algebra Puzzle?
What is the significance of "Oct 9th, 2019" in POTW #387?
The date "Oct 9th, 2019" is the date that the POTW (Problem of the Week) #387 was released. It is simply used to identify the specific problem being discussed.
What does POTW stand for?
POTW stands for "Problem of the Week". It is a common term used in academic settings to refer to a weekly problem or puzzle that is given to students to solve.
Why is evaluating an equation with positive real numbers important?
Evaluating an equation with positive real numbers is important because it allows us to find the specific numerical value of the equation. This can be useful in various fields of science, such as physics, chemistry, and engineering, where precise calculations are necessary.
What are positive real numbers?
Positive real numbers refer to any number that is greater than zero and can be expressed without any imaginary or complex components. These numbers can be represented on a number line and are commonly used in mathematical equations and calculations.
How do you evaluate an equation with positive real numbers?
To evaluate an equation with positive real numbers, you simply substitute the given values for the variables in the equation and solve for the resulting expression. It is important to follow the correct order of operations (PEMDAS) to get an accurate answer.
