Can You Solve This Complex Real Number System Equation?
  • MHB
  • Thread starter anemone
  • Tags
    2016
In summary, the "Real Number System Problem #214 | May 3rd, 2016 POTW Solution" is a mathematical problem featured as the Problem of the Week on May 3rd, 2016. Its purpose is to improve students' understanding of the real number system and develop problem-solving skills. The solution involves using algebraic manipulation and knowledge of real number properties. This problem can be applied in real-life situations such as engineering, physics, and finance. Some tips for solving this problem include remembering the properties of real numbers and breaking down the equation into smaller parts for easier manipulation.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Given $x,\,y,\,u,\,v$ are real numbers that satisfy the following system:
\(\displaystyle x+y+u+v=\frac{1}{2}\)
\(\displaystyle 8x+4y+2u+v=\frac{1}{3}\)
\(\displaystyle 27x+9y+3u+v=\frac{1}{4}\)
\(\displaystyle 64x+16y+4u+v=\frac{1}{5}\)
Evaluate \(\displaystyle 343x+49y+7u+v.\)
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. Theia
2. Opalg
3. kaliprasad
4. MarkFL
Solution from Theia:
By noticing that the solution to the simultaneous equations is the same as coefficients of an interpolating polynomial for points \(\displaystyle (1, \tfrac{1}{2},\ (2, \tfrac{1}{3}),\ (3, \tfrac{1}{4}),\ (4, \tfrac{1}{5})\), one can directly obtain the solution e.g. using Lagrangian method. Let the interpolating polynomial be \(\displaystyle f(t)\), and so
\(\displaystyle \begin{align*}f(t) &= \frac{1}{2} \frac{(t-2)(t-3)(t-4)}{(1-2)(1-3)(1-4)} \\
&\ \ + \frac{1}{3} \frac{(t-1)(t-3)(t-4)}{(2-1)(2-3)(2-4)} \\
&\ \ + \frac{1}{4} \frac{(t-1)(t-2)(t-4)}{(3-1)(3-2)(3-4)} \\
&\ \ + \frac{1}{5} \frac{(t-1)(t-2)(t-3)}{(4-1)(4-3)(4-3)} \\
&= -\frac{t^3}{120} + \frac{11t^2}{120} - \frac{23t}{60} + \frac{4}{5}.\end{align*}\)
Now one can also note that the asked quantity \(\displaystyle l = 343x + 49y + 7u + v\) is equal to \(\displaystyle f(7)\). Thus the result
\(\displaystyle l = 343x + 49y + 7u + v = f(7) = \frac{-1}{4}.\)
Alternate solution from Opalg:
Let $f(n) = xn^3 + yn^2 + un + v$. We are told that $f(1) = \frac12$, $f(2) = \frac13$, $f(3) = \frac14$ and $f(4) = \frac15$. Make a table showing these values in the top row, the differences $f(n+1) - f(n)$ in the next row, then the second differences (that is, the differences of the differences) in the following row, and so on:
$$\begin{array}{ccccccc} 1&&2&&3&&4 \\ \hline \tfrac12 && \tfrac13 && \tfrac14 && \tfrac15 \\ &-\tfrac16 && -\tfrac1{12} && -\tfrac1{20} \\ && \tfrac1{12} && \tfrac1{30} \\ &&& -\tfrac1{20} \end{array}$$ Since $f(n)$ is a cubic polynomial, its third differences must be constant. So the third difference must always be $-\frac1{20}$. We can therefore add some extra elements $-\frac1{20}$ to the bottom row of the table, and then work our way back up to the top row, like this:
$$\begin{array}{ccccccccccccc} 1&&2&&3&&4 &&5&&6&&7 \\ \hline \tfrac12 && \tfrac13 && \tfrac14 && \tfrac15 &&\tfrac2{15} && 0 && -\tfrac14 \\ &-\tfrac16 && -\tfrac1{12} && -\tfrac1{20} && -\tfrac1{15} && -\tfrac2{15} && -\tfrac14 \\ && \tfrac1{12} && \tfrac1{30}&& -\tfrac1{60} && -\tfrac1{15} && -\tfrac7{60} \\ &&& -\tfrac1{20} && -\tfrac1{20} && -\tfrac1{20} && -\tfrac1{20}\end{array}$$
Conclusion: $343x + 49y + 7u + v = f(7) = -\tfrac14.$
FAQ: Can You Solve This Complex Real Number System Equation?
What is the "Real Number System Problem #214 | May 3rd, 2016 POTW Solution"?
The "Real Number System Problem #214 | May 3rd, 2016 POTW Solution" is a specific mathematical problem that was featured as the Problem of the Week (POTW) on May 3rd, 2016. It involves working with the real number system to solve a given equation.
Why is this problem important?
This problem is important because it allows students to practice and improve their understanding of the real number system, which is a fundamental concept in mathematics. It also helps them develop problem-solving skills and critical thinking.
What is the solution to this problem?
The solution to this problem involves using algebraic manipulation and knowledge of the properties of real numbers to simplify the given equation and find the value of the variable.
How can this problem be applied in real life?
The concept of the real number system is used in various fields such as engineering, physics, and finance. Understanding how to work with real numbers can help in solving real-life problems involving measurements, calculations, and financial transactions.
What are some tips for solving this problem?
To solve this problem, it is important to remember the properties of real numbers, such as the commutative, associative, and distributive properties. It is also helpful to break down the equation into smaller, more manageable parts and use algebraic manipulation to simplify it.
