Can You Solve This Intriguing Real Numbers Equation?
  • MHB
  • Thread starter anemone
  • Tags
    2015
In summary, POTW #175 is a mathematical problem that involves proving the equation for real numbers. The equation states that the sum of the squares of two real numbers is equal to the square of their sum. It can be proven using a mathematical technique called proof by induction. Proving this equation is important as it solidifies our understanding of real numbers and serves as a building block for more complex mathematical concepts. It also has many real-world applications in fields such as physics, engineering, computer science, and finance.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let $a,\,b,\,c$ be real numbers all different from $-1$ and $1$ such that $a+b+c=abc$.
Prove that $\dfrac{a}{1-a^2}+\dfrac{b}{1-b^2}+\dfrac{c}{1-c^2}=\dfrac{4abc}{(1-a^2)(1-b^2)(1-c^2)}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution:):
1. kaliprasad
2. greg1313
3. lfdahl
Solution from kaliprasad:
Putting $a = \tan\, A, b = \tan\, B, c = \tan\, C$
We see that we have $a + b + c = abc$.
=> $\tan\, A + \tan\, B + \tan\, B = \tan\, A \tan\, B \tan\, C$
∴ $\tan ( A+B+C ) = \dfrac{\tan\, A + \tan\, B + \tan\, C -\tan\, A \tan B \tan C}{1 - \tan\, A \tan\, B - \tan\, B \tan\, C - \tan C \tan A} = 0$
∴ $A+B+C = n\pi$ for integral $n$.
$2A + 2B +2C = 2n\pi$
∴ $tan ( 2A+ 2B+ 2C ) = \tan 2n\pi = 0$
∴ $\tan 2A + \tan 2B + \tan 2C =\tan 2A \tan 2B \tan 2C$
∴ $\dfrac{2a}{1-a^2} + \dfrac{2b}{1-b^2}+ \dfrac{2c}{1-c²} = \dfrac{2a}{1-a^2} * \dfrac{2b}{1-b^2}* \dfrac{2c}{1-c²} = \dfrac{8abc}{(1-a^2)(1-b^2)(1-c^2)}$
∴ $\dfrac{a}{1-a^2} + \dfrac{b}{1-b^2}+ \dfrac{c}{1-c^2} = \dfrac{4abc}{(1-a^2)(1-b^2)(1-c^2)}$
Alternate solution from lfdahl:
I start with the LHS and choose a common denominator: $(1-a^2)(1-b^2)(1-c^2)$:
\[\frac{a}{1-a^2}+\frac{b}{1-b^2}+\frac{c}{1-c^2}
= \frac{a(1-b^2)(1-c^2)+b(1-a^2)(1-c^2)+c(1-a^2)(1-b^2)}{(1-a^2)(1-b^2)(1-c^2)}\]
If I can show, that the nominator equals: $4abc$, I´m done. Along the way, I make use of the relation:
$a+b+c = abc$ (cf. the underbraces).
\[a(1-b^2)(1-c^2)+b(1-a^2)(1-c^2)+c(1-a^2)(1-b^2) \\\\ =a(1-(b^2+c^2)+b^2c^2)+b(1-(a^2+c^2)+a^2c^2)+c(1-(a^2+b^2)+a^2b^2) \\\\=a - a(b^2+c^2) + abc(bc)+ b - b(a^2+c^2)+abc(ac)+c-c(a^2+b^2)+abc(ab) \\\\=\underbrace{a+b+c}_{=abc}+abc(bc)+abc(ac)+abc(ab)-((ab)b+(ac)c+(ab)a+(bc)c+(ac)a+(bc)b) \\\\=abc+abc(bc)-b(bc)-c(bc)+abc(ac)-a(ac)-c(ac)+abc(ab)-a(ab)-b(ab) \\\\= abc+bc\underbrace{(abc-b-c)}_{=a}+ac\underbrace{(abc-a-c)}_{=b}+ab\underbrace{(abc-a-b)}_{=c} \\\\ = 4abc\]
Thus equality holds in the expression:
\[\frac{a}{1-a^2}+\frac{b}{1-b^2}+\frac{c}{1-c^2} = \frac{4abc}{(1-a^2)(1-b^2)(1-c^2)}\]
whenever the three numbers $a,b$ and $c$ obey the relation: $a+b+c = abc$ and $a,b,c \notin \left \{ \pm 1 \right \}$.
FAQ: Can You Solve This Intriguing Real Numbers Equation?
What is POTW #175?
POTW #175 refers to a mathematical problem proposed by a platform or organization, often for educational or problem-solving purposes. In this case, it is a problem that involves proving the equation for real numbers.
What is the equation for real numbers?
The equation for real numbers is a fundamental mathematical expression that demonstrates the relationship between real numbers. It states that for any two real numbers a and b, the sum of their squares is equal to the square of their sum: a^2 + b^2 = (a+b)^2.
How do you prove the equation for real numbers?
The equation for real numbers can be proven using a mathematical technique called proof by induction. This involves showing that the equation holds for a base case (such as a=1 and b=1) and then proving that if the equation holds for a general case (such as a and b), it also holds for the next case (a+1 and b+1). This process is repeated until the equation is shown to hold for all real numbers.
Why is proving the equation for real numbers important?
Proving the equation for real numbers is important because it is a fundamental concept in mathematics. It helps to solidify our understanding of the relationship between real numbers and serves as a building block for more complex mathematical concepts. Additionally, being able to prove mathematical equations is a crucial skill for any scientist or mathematician.
Are there any real-world applications for the equation for real numbers?
Yes, the equation for real numbers has many real-world applications, especially in fields such as physics and engineering. It is used in various calculations involving real numbers, such as finding the distance between two points on a coordinate plane or calculating the magnitude of a vector. It also has applications in computer science, finance, and other areas where mathematical concepts are used.
