MHB Can You Solve This Set Theory and Binary Number Problem?
The discussion focuses on proving that the function f, which maps subsets of a set S with n elements to binary sequences of n digits, is a one-to-one correspondence. Participants emphasize that each subset of S uniquely determines a binary number based on the presence of its elements, while each binary number corresponds to a unique subset of S. The proof requires demonstrating that every element in the power set P(S) has a unique binary representation and vice versa. Clarifications on the relationship between subsets and binary sequences are provided to guide the proof. The conclusion affirms that the function f is indeed a one-to-one correspondence.
bootleg1
Preparing for an upcoming midterm and this is one of the practice questions from an old test.
The Question:
Let X be a set with n elements, say S = {s1, s2,..., sn}
Let B be the set of binary numbers with n digits. That is, sequences of n terms, each
of which is 0 or 1.
Define f : P(S) --> B (power set of S) as follows: the image of X ∈ P(S) is the
binary sequence b1b2...bn where bi is the truth value of the statement bi ∈ X, for
i = 1, 2, ..., n.
Prove that f is a 1-1 correspondence.
My Work so far:
If A1 = A2 = An, there are n-try relation and A is a subset of An = A x A x ... x A = {(a1,, a2, ..., an) iai + A for each i = 1, ...,n}
Prove: that there are n-tuples.
I am not sure where to go from here, or if my work is heading in the right direction (Speechless)
Any help would be much appreciated!
The Question:
of which is 0 or 1.
i = 1, 2, ..., n.
My Work so far:
Welcome to MHB, bootleg! :)
To prove a 1-1 relation, you need to prove that for every element in P(S) there is a unique associated element in B, and also that for every element in B there is a unique associated element in P(S).
If you take any subset of S, it determines a number in B uniquely, as per the definition of your f.
Each number in B consists of n values of either 0 or 1. If we construct a set with exactly those $s_i$ that have a corresponding 1 in the number from B, we get a unique set that is an element of P(S).
Therefore the relation is 1-1.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
