MHB Can you solve this system of equations with four variables?
  • Thread starter Thread starter anemone
anemone
MHB
POTW Director
Find all real solutions to the following system of equations:
$a+b+c+d=5$
$ab+bc+cd+da=4$
$abc+bcd+cda+dab=3$
$abcd=-1$
Mathematics news on Phys.org
Solution that I saw somewhere online:
We're given
$a+b+c+d=5$
$ab+bc+cd+da=4$
$abc+bcd+cda+dab=3$
$abcd=-1$
Let $X=a+c$ and $Y=b+d$. Then the system of equations is equivalent to
$x+Y=5$
$XY=4$
$Xbd+Yac=3$
$(Xbd)(Yac)=-4$
The first two of these equations imply $(X,\,Y)=(1,\,4)$ and the last two give $(Xbd,\,Yac)=(4,\,-1)$.
And this yields:
[TABLE="class: grid, width: 500"]
[TR]
[TD]$X$[/TD]
[TD]$Y$[/TD]
[TD]$Xbd$[/TD]
[TD]$Yac$[/TD]
[TD]$(a,\,c)$[/TD]
[TD]$(b,\,d)$[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]4[/TD]
[TD]4[/TD]
[TD]-1[/TD]
[TD]$\dfrac{1\pm 2}{2}$[/TD]
[TD]2[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]4[/TD]
[TD]-1[/TD]
[TD]4[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]1[/TD]
[TD]4[/TD]
[TD]-1[/TD]
[TD]-[/TD]
[TD]-[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]1[/TD]
[TD]-1[/TD]
[TD]4[/TD]
[TD]2[/TD]
[/TR]
[/TABLE]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
