Can You Solve This Week's 3D Improper Integral Challenge?
In summary, a 3D improper integral is an integral involving three variables that is evaluated over a region in three-dimensional space. It can be solved by setting up the integral and using techniques such as substitution or integration by parts. Real-life applications include calculating mass and volume, and analyzing fluid flow. Multiple solutions are possible and can be checked using software or using geometric and physical reasoning.
Chris L T521
MHB
915
Thanks to those who participated in last week's POTW! Here's this week's problem.
Problem: Show that
\[\int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \sqrt{x^2+y^2+z^2}e^{-(x^2+y^2+z^2)}\,dx\,dy\,dz = 2\pi\]
(Note that the improper triple integral is defined as the limit of a triple integral over a solid sphere as the radius of the sphere increases indefinitely.)
Here's a hint for this week's problem.
Use spherical coordinates.
This week's problem was correctly answered by Sudharaka and BAdhi. You can find BAdhi's solution below.
\(\displaystyle \int_{- \infty }^{ \infty }\int_{- \infty }^{ \infty }\int_{- \infty }^{ \infty } \sqrt{x^2+y^2+z^2} e^{-(x^2+y^2+z^2)} dxdydz\)
using polar coordinates,\(\displaystyle x=r\sin \theta \cos \phi \)
\(\displaystyle y=r\sin \theta \sin \phi\)
\(\displaystyle z=r\cos\theta \)since the integration occurs for all the values in 3d space, \(\displaystyle 0<r<\infty\)
\(\displaystyle 0<\theta<\pi\)
\(\displaystyle 0<\phi<2\pi\)and due to variable change,\(\displaystyle dxdydz=r^2\sin \theta drd\theta d\phi\)we know that,\(\displaystyle x^2+y^2+z^2=r^2\)because of that,\(\displaystyle \int_{0}^{ \infty }\int_{0}^{\pi}\int_{0}^{2\pi } r e^{-r^2} r^2 \sin \theta drd\theta d\phi\)\(\displaystyle =\int_{0}^{ \infty }\int_{0}^{\pi} r^3e^{-r^2}\sin \theta \left[\phi\right]^{2\pi}_{0} drd\theta\)\(\displaystyle =\int_{0}^{ \infty }\int_{0}^{\pi} r^3 e^{-r^2} \sin \theta (2\pi) drd\theta\)\(\displaystyle =(2\pi)\int_{0}^{ \infty } r^3 e^{-r^2} \left[-\cos \theta\right]^{\pi}_{0} dr\)\(\displaystyle =(2\pi)\int_{0}^{ \infty } r^3 e^{-r^2} [2] dr\)\(\displaystyle =(4\pi)\int_{0}^{ \infty } r^3 e^{-r^2} dr\)now use the substitution,\(\displaystyle t=r^2\)
\(\displaystyle dt=2r dr\)
\(\displaystyle 0<t<\infty\)then,\(\displaystyle (2\pi)\int_{0}^{ \infty }t e^{-t}dt\)\(\displaystyle =2\pi\left( \left[-te^{-t}\right]_{0}^{\infty}+\int_{0}^{\infty}e^{-t}dt\right)\)by l'hopitals rule to \(\displaystyle e^{-t}\) we can get that, \(\displaystyle te^{-t}=0\) when t goes to infinitythen,\(\displaystyle =2\pi\left( \left[0-0\right]+\int_{0}^{\infty}e^{-t}dt\right)\)\(\displaystyle =2\pi\left( \int_{0}^{\infty}e^{-t}dt\right)\)\(\displaystyle =2\pi\left(-e^{-t}\right)_{0}^{\infty}\)\(\displaystyle =2\pi\left(0-(-1)\right)\)\(\displaystyle =2\pi\)because of this,\(\displaystyle \int_{- \infty }^{ \infty }\int_{- \infty }^{ \infty }\int_{- \infty }^{ \infty } \sqrt{x^2+y^2+z^2} e^{-(x^2+y^2+z^2)} dxdydz=2\pi\)
FAQ: Can You Solve This Week's 3D Improper Integral Challenge?
What is a 3D improper integral?
A 3D improper integral is an integral that involves three variables and is evaluated over a region in three-dimensional space. It can also be thought of as the volume under a three-dimensional surface.
How is a 3D improper integral solved?
To solve a 3D improper integral, the first step is to set up the integral by expressing the bounds of integration in terms of the three variables. Then, the integral can be evaluated using various techniques such as substitution, integration by parts, or trigonometric identities.
What are some real-life applications of solving a 3D improper integral?
3D improper integrals have various applications in physics, engineering, and economics. They are used to calculate the center of mass of a three-dimensional object, determine the volume of a three-dimensional shape, and analyze the flow of fluids in engineering problems.
Can a 3D improper integral have multiple solutions?
Yes, a 3D improper integral can have multiple solutions depending on the region of integration and the function being integrated. It is important to carefully consider the bounds of integration and the properties of the function in order to find the correct solution.
How can I check if my solution to a 3D improper integral is correct?
One way to check the correctness of a solution to a 3D improper integral is to use software such as Wolfram Alpha or MATLAB to evaluate the integral and compare the result to your solution. Additionally, you can also check your solution by using geometric or physical reasoning to verify if it makes sense in the given context.
